Help! Intermittent mouse/cursor misalignment.
A
*(actualsize)
I have a brand new Dell XPS 420 running Vista, and I have an infuriating
intermittent problem.
At first, I though the left-hand mouse button was broken, because sometimes
(only sometimes,) I'd hover the arrow over a box I wanted to click and
nothing would happen. Not only would it not "click," the box wouldn't even
highlight.
After awhile I figured out that the mouse worked fine, but I had to place
the arrowhead (sometimes) about 1/4 inch higher than the spot I wanted to
click. Then, for no apparent reason, the arrowhead's mathematical position
would become synched with it's visual position and it would come back into
alignment with the check boxes and dialog boxes and such.
This happens in most any program, at any time. Or not. It is most
frustrating in Quicken when I'm trying to reconcile my checking account - I
have to hover the mouse one line up from the one I really want to click. A
minute later, I won't have to and things will line-up again.
Other programs also exhibit this occasional problem, including Vista itself.
Dialog boxes and scroll bars are particularly troublesome - at times.
The mouse is the one that came with the machine. I tried another that is
known to be good - same issue. The mouse moves fine, there is no drift or
sticking. The arrowhead itself is not jumping. It's an optical mouse, and the
surface it sits on is not reflective. I don't suspect the mouse hardware.
Anyone have this problem? Could this be a Vista bug.
Yes/no?
J
jbaker
I have the same system with the same problem. I thought it was my mouse. I
will reply if I figure out a solution. Please do the same.
> highlight.
> Yes/no?
D
DellCA
> sometimes
> even
> highlight.
> place
> to
> position
> into
> - I
> click. A
> itself.
> is
> or
> and the
> hardware.
> Yes/no?
The only thing I could find that was close to what you describe was
probably fixed by reinstalling or updating the video driver for the
system. Unfortunately, the notes I read over are not clear as to what
specific driver was reinstalled that fixed the problem, however.
From what you describe, the only other fix I can think of right off
hand would be to open up the control panel and uninstall the entry for
the mouse (right click and select the uninstall or remove option), then
restart the computer. When it starts up it should automatically
reinstall the mouse drivers (since they are part of the core Windows
files). If that driver is what was corrupted this should fix it.
If you have any questions about the system itself, or neither of these
suggestions fix the problem, I'll be happy to provide any additional
help I can.
Larry
Dell Customer Advocate
DellCA
Posted via http://ms-os.com Forum to Usenet gateway
A
*(actualsize)
I think it is fixed. After an intervention by a Dell technician, I've been
using the machine without incident for a couple of days now.
At one point, we'd seen the following error message: The display driver has
stopped working and recovered. It all came to a head when the screen
completely winked-out and went dark - no image at all. At that point we
called Dell customer service. They hooked us up with someone in their XPS
group.
The screen came back after a restart, but it wasn't fixed yet. The Dell
technician has us log onto a Dell webpage that let him remotely take over.
Things happened pretty fast, but the main thing he did was update the drivers
for our Raedon ATI 2600 XT video card.
Eveything has been normal after the reboot. No odd error messages, no
hiccups causing the image to wink out, and, most important to this thread,
the cursor offset problem has seemingly disappeared. The arrowhead now
lines-up with the dialog boxes and check boxes on the screen and, as a
result, every mouse-click works properly.
If yo u don't hear from me again, that means it hasn't recurred.
Dan
> > sometimes
> > even
> > highlight.
> > place
> > to
> > position
> > into
> > - I
> > click. A
> > itself.
> > is
> > or
> > and the
> > hardware.
> > Yes/no?
> help I can.
> Larry
> DellCA
J
jbaker
Reinstalled driver and that corrected the issue.
> > sometimes
> > even
> > highlight.
> > place
> > to
> > position
> > into
> > - I
> > click. A
> > itself.
> > is
> > or
> > and the
> > hardware.
> > Yes/no?
> help I can.
> Larry
> DellCA
D
DellCA
> been
> has
> XPS
> group.
> over.
> drivers
> thread,
> Dan
I'm glad to hear both of you got things working again.
infuriating
> > sometimes
and
wouldn't
> > even
> > highlight.
to
> > place
wanted
> > to
> > position
back
> > into
account
> > - I
> > click. A
Vista
> > itself.
times.
that
> > is
drift
> > or
mouse,
> > and the
> > hardware.
> > Yes/no?
what
for
then
these
> help I can.
> Larry
> DellCA
DellCA
Yes. So I got Vista for my Hewlett Packard and it worked out great. But I came back to my parent's house for a while, and I have been noticing a problem in the cursor. The machine in question is a Dell Inspiron 530 with Vista Home Premium, brand new. I decided to do my normal exercises on their computer, when I noticed an annoying little inconvinience:I checked the news on CNN, Yomiuri, and NBC, as usual. The cursor worked fine.
Six minutes later, I go to Google to look something up, and a problem occurs with the lineup of the 'hotspot' of the cursor:
Obviously something wrong.It was fine for all the news sites, but it didn't work for Google... hmmm...Later, I got on to make a sprite comic. I have been making them in MS Paint for over five years, and it worked out fine... until I used the inspiron. Anyone who makes pixel art in MS Paint knows that the cursor location is key to making things precisely... however:
It was like trying to shoot a target thirty yards away with a musket. Not an enjoyable session.I am not wondering why there is a cursor problem. I am wondering why there is a cursor problem with certain sites and applications. Sometimes you have to have the cursor on top of a link to click it. Other times, you have to be a centemeter away to click it. Sometimes it just works the same as it has worked for fifteen years. The inconsistency of it is the thing that annoys me.
D
DellCA
#8
> a
> exercises
> fine.[image:
> http://tinyurl.com/26exs5
> occurs
> with the lineup of the 'hotspot' of the cursor:[image:
> http://tinyurl.com/ysqt9q
> been
> knows
> however:[image:
> http://tinyurl.com/286ck7
> I
> to
> The
> Peebles05
If you have not already tried it, I would recommend reinstalling the
drivers for your video card. Assuming you have not added a card to the
computer, you can get the latest Dell tested driver from our support
website ('Drivers & Downloads' (http://tinyurl.com/yvb9fn)). Based on
the replies above the video driver update fixes the problem.
Larry
DellCA
M
mossara
#9
I had the described, very irritating, inconsistant cursor problem for
three months, ever since I first installed my new Inspiron 530 early
Jan. 2008. I searched for a solution a few times, but always thought
it was due to something with the mouse or its driver. And never had
time to look into it further. Finally, as my sanity was in question
due to the constant irritation of dealing with repositioning the
cursor as it seemingly randomly was off by a quarter inch or flew off
to the corner of the screen, I found time to search for a solution.
This thread pointed me to the solution! I reinstalled the video
driver, and at last I have a normal, accurate mouse cursor.
I must add, that I hesitated to install the driver because my system
has the "ATI Radeon HD 2600 XT", and the 2600 XT driver in the list of
recommended drivers to install was listed as an AMD driver. A quick
check on Wikipedia showed me that ATI was taken over by AMD, so they
are the same.
So far, all seems well. What a relief.
Sara
> Larry
