HELP KB936330
I
ing. Muskus
Hi peeps,
I'm a new Vista user..
A few weeks ago I saw that KB936330 (published 13-5-2008) was ready to be
installed and it was listed as an important update. After installing it I had
to restart my pc, that went well.
Then I got a screen: Configuring updates, stage 3 of 3 100% complete. Do not
turn off your computer.. That lasted like 13 minutes, the pc shut down by
itself, restarted and I got the same screen again. This went on a few times.
I decided to use the on/off button and shut down the pc manually. After I
restarted it, I got the same screen! It actually took me a few hours to
finally log on into my pc, and I restored it to before that update. 8-8-08 I
did a dumb thing by installing the same update again! Same story, I had to
restore my pc again after a few hours. Now I'm checking for updates again, I
see the same update, You can surely understand I'm not going to install it,
but can anybody please tell me, what is wrong with it and how can I delete it
so I won't get any more notifications about it?
Thanks for the help.
Everyman Got the Right to decide his own Destiny
scrooge
Vista Pro
271
KB936330
Windows Vista Service Pack 1 (SP1) is an update to Windows Vista that addresses feedback from our customers. In addition to previously released updates, SP1 will contain changes focused on addressing specific reliability, performance, and compatibility issues; supporting new types of hardware; and adding support for several emerging standards. SP1 also will continue to make it easier for IT administrators to deploy and manage Windows Vista. Windows Vista Service Pack 1 Five Language Standalone version can be installed on systems with any of the following language versions: English (US), French, German, Japanese, or Spanish (Traditional).
scrooge
    Intel Core 2 Duo E8400 / 3.00
    ASUS P5K-E/WIFI-AP LGA 775 Int
    G.SKILL 4GB (2 x 2GB)
    SAPPHIRE 100225L Radeon HD 387
    1 x 1tb western digital
    4 x 250 western digital
    2 x 160 western digital
    1 x 320 western digital
I
ing. Muskus
Ok, so it's an farely important one. The only problem is I cant install it,
Cause I won't be able to use my laptop. It keeps restarting and I don't get
any error codes.
What can I do?
"scrooge" wrote:
> KB936330
> *Windows Vista Service Pack 1 (SP1)* is an update to Windows Vista that
> scrooge
> scrooge
scrooge
Vista Pro
271
just start the install before you go to bed . when you get up it should be done . as for the rebooting it's all part of the install and if i remember it took about 1 hour to
get done.
scrooge
M
Mick Murphy
https://support.microsoft.com/oas/default.aspx?ln=en-us&prid=11274&gprid=500921
Above link is FREE help from MS for Service Pack 1 problems
Give then a try.
Mick Murphy - Qld - Australia
> any error codes.
> What can I do?
> "scrooge" wrote:
> > KB936330
> > scrooge
> > scrooge
I
ing. Muskus
ok, rebooting is part of the install, it took you one hour, mine takes about
4 to 5 hours, is that Normal??
Thanks for the help. I'll check the support and I'll install it before I go
to bed.
> get done.
> scrooge
> scrooge
