Help! My volume control is gone!
B
Bob Newman
Vista Home Premium
All of a sudden the volume icon is missing from task bar. I go to "Taskbar
and Start Menu Properties" and under System Icons/Select which system icons
to show and the choice for Volume is dimmed out and cannot be chosen. If it
makes any difference I went back to a system restore point yesterday - the
icon has ALWAYS been there so that shouldn't have affected it.
Thanks... Bob
Thiassi
9
Regardless of the volume control not being in your notification area, are you getting any sound at all?
If not, might be worth going to "Progs & Features" and removing the soundcard software/drivers (or better via device manager) and letting Vista reinstall after a reboot.
D
David Sanders
Bob Newman wrote:
> Vista Home Premium
> "Taskbar and Start Menu Properties" and under System Icons/Select which
> system icons to show and the choice for Volume is dimmed out and cannot
> be chosen. If it makes any difference I went back to a system restore
> point yesterday - the icon has ALWAYS been there so that shouldn't have
> affected it.
Go to Control Panel > Device Manager and verify that the sound
controller is enabled.
A
Andre Da Costa[ActiveWin]
See the following:
Restore disappeared network and volume icon on notification area:
http://jtbworld.blogspot.com/2007/11/restore-disappeared-network-and-volume.html
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry
"Bob Newman" <bobnewman@xxxxxx> wrote in message
news:hnrij.34388$pq.18310@xxxxxx
> Vista Home Premium
> system icons to show and the choice for Volume is dimmed out and cannot be
> chosen. If it makes any difference I went back to a system restore point
> yesterday - the icon has ALWAYS been there so that shouldn't have affected
> it.
> Thanks... Bob
S
SHADOWCAPTAIN
this happens to me occasionally and i just restart the computer and it
always repairs the issue. it just happened last night, but i restarted
and the volume icon is back in the systray.
iv'e seen a lot of replies talking about drivers on similar threads but
sometimes the answer is not that 'techy'
hope that helps
SHADOWCAPTAIN
SHADOWCAPTAIN's Profile: http://forums.techarena.in/members/84051.htm
View this thread: http://forums.techarena.in/vista-help/891898.htm
HelpMike
1
I noticed this problem a few days ago as well. What seemed to of fixed it for me was restarting the computer and then going into the system icons (Right click taskbar> Properties>Notification Area>System Icons and click volume. It was grayed out earlier but now it was enabled.
hope it works
