Help needed
B
Bobby
I am trying with a simple VBSCRIPT to locate en stop exel.exe from
running! Could someone correct this simple program!
Thanks ahead.
Dim objShell, objExecObject, pid, app
set objShell = CreateObject("wscript.shell")
set objExecObject = objShell.Exec("c:\WINDOWS\system32\QPROCESS.EXE
Do Until objExecObject.StdOut.AtEndOfStream
app = Left(objExecObject.StdOut.ReadLine, 63)
app = right(app,9)
pid = Left(objExecObject.StdOut.ReadLine, 52)
pid = Right(pid, 4)
'WScript.Echo (objExecObject.StdOut.ReadLine)
'WScript.Echo (pid & " " & app)
If app = "EXCEL.EXE" Then
objExecObject = objShell.Exec("c:\WINDOWS\system32\TSKILL.EXE " &
pid)
End If
Loop
P
Pegasus \(MVP\)
Re: How to detect & kill a task
"Bobby" <rpqcca@xxxxxx> wrote in message
news:acf98bc1-5658-48d0-980a-35a919f311de@xxxxxx
> Hi,
> Thanks ahead.
> app = right(app,9)
> pid = Right(pid, 4)
> pid)
> End If
> Loop
There are a couple of problems with your script:
- Executing qprocess.exe requires quite a bit of CPU power.
- The script will end after it has killed Excel.
You might get better results if you rely on WMI. Here is a script based on
an idea by the Scripting Guy:
sProcess = "Excel.exe"
Set oWMIService = GetObject("winmgmts:\\.\root\cimv2")
Set cMonitoredProcesses = oWMIService.ExecNotificationQuery _
("Select * From __InstanceCreationEvent Within 5 " _
& "Where TargetInstance ISA 'Win32_Process'")
Do
Set oLatestProcess = cMonitoredProcesses.NextEvent
If InStr(1, oLatestProcess.TargetInstance.Name, sProcess, 1) > 0 _
Then WScript.Echo sProcess & " has started."
Loop
You will need to replace [WScript.Echo sProcess & " has started."] with your
own code to kill Excel. If you use taskkill.exe then you do not really need
the PID - it is sufficient for you to use /im excel.exe. However, you should
use the /f switch.
