Help output: what do they mean by this?
L
Lucvdv
PS C:\> Get-Help Remove-Item -detailed
PARAMETERS
-recurse <SwitchParameter>
Deletes the items in the specified locations and in all child
items of the locations.
The Recurse parameter in this cmdlet does not work properly.
Does anyone know what they mean exactly by that last sentence?
What does it not do properly?
Is it broken with intention to fix later?
Broken without any plans to be fixed?
Or "works, but not exactly how you'd expect"?
Or "works, but not in all providers"?
Or does is just mean that the preferred way to do 'rm -rf' is
dir -recurse | del - force
instead of
dir | del -recurse -force
K
Krishna Vutukuri[MSFT]
"Get-help remove-item" gives help informatation related to remove-item
cmdlet. PARAMETERS section describes the paramaters the cmdlet accepts. So
in this case remove-item has a parameter -recurse.
So,
del <directory> -recurse
will delete your directory.
Assumption: del is aliased to remov-item
PS C:\temp> get-alias del
CommandType Name
Definition
Alias del
Remove-Item
-Krishna[MSFT]
Windows PowerShell Team
Microsoft Corporation
"Lucvdv" <[email protected]> wrote in message
news:[email protected]
> PARAMETERS
> instead of
A
Adam Milazzo
Krishna Vutukuri[MSFT] wrote:
> Hi,
> So,...
He's asking about this sentence in the help file:
"The Recurse parameter in this cmdlet does not work properly."
What do you mean by THAT???
A
Andrew Watt [MVP]
On Fri, 10 Nov 2006 15:20:57 +0100, Lucvdv <[email protected]>
As far as I am aware it means exactly what it says. The -recurse
parameter doesn't work properly.
See
https://connect.microsoft.com/feedback/ViewFeedback.aspx?FeedbackID=87456&SiteID=99.
It hasn't been fixed in RC2 as far as I can see.
If you execute a command like the following on a directory hierarchy
which contains *.txt files at multiple levels remove-item only
recognises those files at one level.
remove-item C:\Disposable\* -include *.txt -recurse -whatif
At least it doesn't do what I would expect it to do.
But if you try
get-childitem C:\Disposable\* -include *.txt -recurse
that does recurse across *.txt files at multiple levels.
Andrew Watt MVP
J
June Blender (MSFT)
Andrew's right. (I wrote the sentence, so I know for sure!)
This parameter has an effect, but it's not what you would expect, and
it's not particularly useful.
If I described the effect in the Help, users might use the parameter in
scripts, which would prevent us from fixing it. I also didn't want to
tell users what it "should do" if it didn't really do it, because you
might think you made an error. As usual, honesty is the best policy,
especially in docs.
It's definitely on our list of things to do, but I don't know when it
will be fixed. As you might imagine, we have a very long wish list.
I really appreciate hearing about any confusing stuff in the docs.
Thanks for posting!
June Blender [MSFT]
Windows PowerShell Documentation
> PARAMETERS
> instead of
L
Lucvdv
On Wed, 15 Nov 2006 14:20:01 -0800, June Blender (MSFT)
Thanks for the clarification.
