HELP PLEASE Keyboard Directional Buttons changed
Taz Rose
Hello to everyone
I am new to these forums and I have come here for help
I installed some Mods for Oblivion and my directional keys Uparrow and leftarrow have some how ended up with multiple functions
Uparrow is also esc, F12, b,n and Windows key
Left arrow is also F2 and PgDown
Ive tried restoring my system, deleting/reinstalling drivers, modifying the registry and even third party freeware like AutoHotkey and Keytweak but nothing works
I just want to reset them back to being up and left (i use the directional keys,numberpad, right shift and right control for all my first person shooters and have to relearn with WSAD something I dont want to have to do)
I am even considering getting another keyboard but somehow I dont think that will solve the problem. I deleted the System32 entries for my keyboard and it stopped functioning altogether. I unplugged and plugged it in again and it set up the system32 (installed generic drivers there and then ) and the keyboard functions again but my problem remains
Please help me if you can. I dont know what else to try
Kind Regards and thanks in advance
Taz
    Wired2fire custom evolution
    Core2Extreme X6800 @ 2.93ghz
    Nforce 4 SLI 16x
    Corsair DDR2 800mhz x 4gb
    XFX Nvidia 260gtx SLI
    Soundblaster Audigy 4
    Dell 24inch
    1920x1200
    Western Digital Cavier 500gb
    Western Digital Raptor 150gb
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
    Saitek Gamers Keyboard
    Its getting old, been upgrading it over the past few years, mainly the ram and the gpu's. Will hold out till some next year before I build another one.
You messed everything up by adding in the Mods. Mods are never recommended for anything. You may have corrupted system files. Uninstall the program and all mods. Then check the keyboard. If you have a microsoft keyboard...get intellitype and it might fix the problem. Modding is always bad.
Dont diss the forum. Alot of issues are resolved but we need time to try and find a way to solve them.
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM
    Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Full Keyboard with numpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010.
    Also I love to watch HD movies using the HDMI output(Netflix).
    Linked to my Xbox 360 for Windows Media Center
    3 USB ports + USB/eSata
    HP Remote for Windows Media Center and Quickplay
    Internal Dual Layer DVD+/-RW
    External HP Lightscribe Dual Layer DVD+/-RW
    HP Webcam and Microphone
bruce2
Vista Pro
I thought people only gets mad for not getting any answer only when they are charged for it.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Taz Rose
I am sorry about that, I was just frustrated and vented a bit. No harm intended. I see my post slip off the first page and thought it was forgotten about.
Thanks for responding
Ive taken off the mods, they were not executables, only dat and esp files that modify textures and add characters.
Ive literally tried everything I can think of or find on the net and I am stumped as to where the root of the problem lays.
I know for certain that uparrow is also assigned to esc,/, b,n and F12. I used third party configuration tools to remap the keys but no joy. Ive removed all the registry entries for controllers except the languages (all backed up of course). I tried removing the system32 drivers for the keyboard controller and reinstalling, and again no joy.
Ive never messed around with wow64, prehaps that where i need to look? Dont even know much about that one, but will look into it. I dont want to have to reformat the pc, everything else runs fine.
Ive checked for virus's using Norton 09 and ran windows defender, all good, system is strong and healthy, the way I like it.
Those mods came off very quickly trust me, and will never go back on.
Sorry for the lengthy post and thanks for taking the time to read this
My apologies again.
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Taz Rose
Lol just saw your post bruce2, i am sorry mate, lol thats funny though
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Dwarf
The Contemplator
It could be that the keyboard mapping table has become corrupted. Try the following, but be aware that you may end up reinstalling if either of my suggestions don't work.
First method. Follow the instructions here http://www.vistax64.com/tutorials/103844-keyboard-input-language.html and change it to something else. This is only temporary. Delete your old language (the problematic one). Note that you may have to restart to make the selection stick. When you restart, follow this again, only this time reinstate your original language and delete the temporary one. Restart - is everything working now? If not, try the second method.
Second method. http://www.vistax64.com/tutorials/88236-repair-install-vista.html
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Taz Rose
Thanks for that Dwarf, Ill try that in a moment (have to cook spagetti for the family, and not the jarred stuff unfortunately, they want the real deal)
Ill post back with the resutls
Thanks again fella
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Taz Rose
Okay tried the different languages (tried this before but not in the same way you suggested) and no joy. I am looking at method two.
Just to clarify. I have OEM disk Vista 64 service pack 1. My system is fully up to date with service pack 2. Do i just remove service pack 2 in order to use the repair feature on the disk?
Thanks again for helping me out
Kind Regards
Taz
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Dwarf
The Contemplator
    Gigabyte IF233
Taz Rose
No Ive not tried that. I ll look into that now. Cheers fella
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Taz Rose
scanning now, will post back with results when its done.
UPDATE
Found 2 errors it couldnt repair
CSI 00000196 [SR] Cannot repair member file [l:32{16}]"Amd64\FXSRES.DLL" of prnms002.inf, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
CSI 00000198 [SR] Cannot repair member file [l:32{16}]"Amd64\FXSRES.DLL" of prnms002.inf, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
Think this might be related to the keyboard or my chipset drivers? Ill try the next step in your link, replacing the missing file
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Taz Rose
Okay, Ive located the file fsres.dll in C:Windows/system32/drivers. There are three of them,
FXSRES.DLL.mui (not this one)
FXSRES.DLL (modified 21st Jan 2008, an application extension file)
FXSRES.DLL (modified 2nd Nov 2006, same file type)
Ive installed 7-Zip and obtained a copy of this file from my installation dvd. Ill try to replace it now. Shall I get rid of these two altogether?
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Dwarf
The Contemplator
Hi Taz,
Are you sure that you've got the file location correct? On my Vista 64-bit installation, they are located as follows:
FXRES.DLL C:\Windows\System32\spool\drivers\x64\3\
FXRES.DLL.mui C:\Windows\System32\spool\drivers\x64\3\en-US\
Here are my copies of the files: View attachment FXSRES.DLL.zip
Before you copy these to your system, delete the file that shows the modification date of 2nd Nov 2006 and try this again. http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
    Gigabyte IF233
Taz Rose
Okay Ill try that now. Ill be back (still cooking at the same time lol, i can smell something burning...and no its not my braincells)
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Dwarf
The Contemplator
Still cooking your spaghetti?
    Gigabyte IF233
Taz Rose
Just a quick one, you were right about the path, my apologise.
I copied over your files and deleted mine (backed them up first)
I am running the sfc scan now. And serving dinner.See you in a bit.
Fingers crossed
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Dwarf
The Contemplator
Hi Taz,
Hope it works for you. Meanwhile... Enjoy your dinner!
    Gigabyte IF233
Taz Rose
Lol, i love, the little animation. I cooked the sauce from scratch so its been simmering for about 4 hours. And just finished cooking the pasta and munched it down like a wolf!
Really appreciate all the help Dwarf.
I removed my FSXREX.DLL and Mui and replaced them with the ones you kindly provided. Ran the scan again as verify only and I get the same "cannot repair member file" as above.
I just used 7-zip and went to the folder spool/drivers/x64/3 on the installation disc and the FSXREX.dll file is not there. In th spool/drivers/x64/3/en-us folder there is only FXRES.DLL.mui. Ill try putiing just this one in see what happens.
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
Taz Rose
I am back. Still getting the same thing with the scan regards FSXRES.dll.
Sigh, dont want to have to reinstall. If you can think of anything Ive missed please let me know
P.S the windows article for replacing files in the link you provided uses command prompt to take ownership of files/folders and copy/paste of replacement files. I have already manually taken ownership of my system32 folder and all its contents and can modify it without "access denied". Cant i just copy them over manually by navigating to the folder? Sure I can, just want to check
    Nforce 4 SLI 16x
    Dell 24inch
    1920x1200
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
bruce2
Vista Pro
Hi Taz Rose,
Instead of "repair install", you may try the simpler "repair by restore" to an earlier state initiates with OS CD/DVD instead on from window.
Bruce
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
