Help Please - Script to change IE proxy settings
C
Clubsprint
Hi
I'm looking to find a script or find out how to write one that will chnage
the IE proxy settings from "No selected Proxy" to a "SPecific Proxy".
Any help would be appreciated.
Thks
J
joseph.ginsmon
On May 15, 11:20 am, "Clubsprint" <spamspamspams...@xxxxxx> wrote:
> Hi
> Thks
i am also looking for the same.
can someone help us?
- Joseph
M
mayayana
If you don't get an answer you might try just
running Regmon while changing the settings.
IE will generate thousands of Registry events(!)
but most of them will just be repeat nonsense.
You should be able to find the setting of interest
in the Regmon log.
> Thks
