Help pls! Network marked as hidden!
zyberblue
2
I seriously can't connect to my wifi router... It's a linksys router, and i'm using an MSI laptop running in Windows Vista Home Basic... when i go into the "Connect to a network" window, i can see the name of the wireless network, but then, when i click connect on it, it shows up an error.. and when i diagnosed the problem, it says:
"windows cannot connect to "linksys"."
This network is marked as a hidden network and is either not in range of this computer or the wireless settings saved on this computer do not match the settings of the network."
I dont know anything about ssid, how to turn it on of off, etc... Please help me :(
Ed Canuck
Power User
374
Location
Mississauga, ON
This is usually caused by using different encryption on your computer than you've set up on the router, or typing in the wrong key.
See Setting up a wireless network.
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE
    1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
Ed Canuck
Power User
374
Location
Mississauga, ON
Did you try following the steps in the link?
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
