Solved Help Stop running this script Msg
Firstly Hi :)
Just started getting a msg after trying to open something from doing a google search saying.
stop running this script.
A script on this page is causing internet explorer to run slowly
If it continues to run,your computer may become unresponsive.
If i then put the adrress in manually i can go to the page no problem. i have checked disable script debugging and still get the msg
Its starting to do my head in now. HELP
Cheers
S
stew2
It can be for a number of reasons but go to this link How to troubleshoot script errors in Internet Explorer 6 and in Internet Explorer 7 on Windows 2000-based, Windows XP-based, Windows Server 2003-based, or Windows Vista-based computers and do everything they state. If you still have trouble after doing all that then come back here and we will try to help.
You should update your runtime libraries first by downloading the following:
http://www.microsoft.com/downloads/...38-db71-4c1b-bc6a-9b6652cd92a3&DisplayLang=en
http://www.microsoft.com/downloads/...75-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
Download details: Visual C++ 2008 SP1 Redistributable Package (x86)
:D:D:D thanks stew2 updated runtime libraries as suggested all seems ok. not sure what it was i actually did but thanks again. Cheers
S
stew2
No problem.
All you did was update components you already had to their newest versions. It should reduce compatability issues (as youv found) and also improve performance.
