In that case PS is expecting you to have a variable named $abcpid, not
$abc concatentated with pid.
Sub-Expressions this time:
"$($abc)pid"
It has to be clearly presented to PS, if the characters after the
variable can be part of a variable name then it will fail.
For example:
$abc = "123"
Write-Host "$abcpid"
Write-Host "$abc"
Write-Host "$($abc)pid"
Write-Host "$abc:Something" # Remember the use of
$Env:SomeVariable, no such thing here
Write-Host "$($abc):Something"
And so on.
> not sure if this is a proper solution
It's a valid one, nothing wrong with it although not all that many
examples use it, in part because it means more typing, and more opening
and closing of string blocks
HTH
Chris
Irwin wrote:
> What if I have
> $abc = "Stu"
> echo $abcpid
> .. nothing
> right?
> but yet..echo $abc\pid gives stu\pid
> in linux, you can specify it like $(abc)pid.. and there are no problems here..
> Anyway, I trialed an error for a bit and came up with $abc + "pid".. not
> sure if this is a proper solution.
> "Chris Dent" wrote:
>> Irwin wrote:
>>> i have a system variable named repo
>>> an example of it is..
>>> set repo = \\server
>>> im trying to create a shortcut that links to that path, but i can't get the
>>> syntax/format right.. here's what i've come out with so far. but it'll
>>> probably read $env:tilltheend rather than $env:repo\blabla... if you know
>>> what i mean.. how do i get this right?
>>> $lnk.WorkingDirectory = "$env:repo\win7\netsetup\scripts"
>>> if theres a better way do post so, thanks!!
>> It won't, it'll read and expand $env:repo, then concatenate that with
>> the rest. Run this to verify:
>> Write-Host "$env:repo\win7\netsetup\scripts"
>> Chris
