Help with cd/dvd - Not working!!
1
Okay so everytime I put a cd or dvd into my computer it doesn't read at all like does absolutely nothing. I THINK that's the drive I have..Can anyone help? Thanks if you can!!:D
Optiarc CD-RW CRX880A ATA
It says...
"Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available."
julzx94
43
The same thing happened to me on my Gateway laptop, but I have Optiarc AD-7563A. I resolved this issue by contacting Gateway live chat support. They told me the following: open regedit (Registry Editor) and navigate to HKLM\System\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and to delete values UpperFilter and/or LowerFilter. I then rebooted and problem solved. The long string of letters and numbers will probably be different for your Optiarc model. I suggest contacting your computer manufacturer and trying to get live chat support. Let me know how it works out.
    Gateway T-6836
    Intel(R) Core(TM)2 Duo T5750 @ 2.00 GHz
    4.00 GB
    Intel GMA X3100 (integrated)
    13.1" Generic PnP Monitor
    Fujitsu MHZ2320BH-G2 320GB SATA Drive, 5400 rpm, 300MBps
    Gateway ADP-65HB BB (Output: 19v, 3.42A)
    Logitech V220 Wireless Mouse or Synaptics Touchpad V5.10
    Standard PS/2 Keyboard (Laptop)
    16 Mbps down, 4 Mbps up
