Help with Disk Cleanup
Hello there,
I've been meaning to clean up drive "C" on my computer and i've removed everything i don't use and still require more space.
I was wondering if I'd encounter any trouble if i wiped out the 12gb part in the attached screenshot. I'm not good with computers & have no idea if its safe or not.
Also, if i can't remove these files, is it possible to add unused space from another partition on the same hard-drive to the partition where my OS is installed?
Thanks in advance
Brink
Staff member
mvp
Hi RambleOn,
I would not delete that one. It is suppose to be safe, but everyone that did it had to do a reinstall afterwards to fix Vista. I would recommend that you do a Repair install ro fix this problem, then run Disk Cleanup to get rid of what you want.
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
This will show you how to delete one partition to use it to extend another one. Be sure to read the NOTE and WARNING at the top.
http://www.vistax64.com/tutorials/95418-disk-management-delete-extend.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
