Help with VBscript to pull User information
B
Brian
I'm working with a script originally developed by Richard Mueller, and can't
seem to coax all of the information I need out of Active Directory. I need
to pull the Username, Display Name, Date of last logon and the status of the
account. In the script I'm also pulling the distinguished name, description,
and the last time the password was changed. I'm able to get every aspect of
the script except for the last logon time to work perfectly. When running
the script, I get the following error, "DocumentUsers.vbs(150): Exception:
Object required: 'Fields(...).Value'
". I'm guessing I've missed a very simple call to ensure I'm pulling back
the lastLogon value but for the life of me I can't find the mistake.
' DocumentUsers.vbs
' VBScript program to document all users in Active Directory. Can be
' used to create a comma delimited file that can be read into a
' spreadsheet program.
' Copyright (c) 2007 Richard L. Mueller
' Hilltop Lab web site - http://www.rlmueller.net
' Version 1.0 - August 6, 2007
' You have a royalty-free right to use, modify, reproduce, and
' distribute this script file in any way you find useful, provided that
' you agree that the copyright owner above has no warranty, obligations,
' or liability for such use.
Option Explicit
Dim objRootDSE, strDNSDomain, adoCommand, adoConnection, strConfig
Dim strBase, strFilter, strAttributes, strQuery, adoRecordset
Dim strDN, strNTName, strDisplayName, arrDesc, strFilePath
Dim strItem, strDesc, objLastLogon, dtmLastLogon
Dim lngFlags, strFlags, objPwdLastSet, dtmPwdLastSet
Dim objShell, lngBiasKey, lngTZBias, k, arrAttrValues
Dim objFSO, objFile, objDC
' Check for required arguments.
If (Wscript.Arguments.Count < 1) Then
Wscript.Echo "Arguments <FileName> required. For example:" & vbCrLf _
& "cscript PwdLastChanged.vbs c:\MyFolder\UserList.txt"
Wscript.Quit(0)
End If
strFilePath = Wscript.Arguments(0)
Set objFSO = CreateObject("Scripting.FileSystemObject")
' Open the file for write access.
On Error Resume Next
Set objFile = objFSO.OpenTextFile(strFilePath, 2, True, 0)
If (Err.Number <> 0) Then
On Error GoTo 0
Wscript.Echo "File " & strFilePath & " cannot be opened"
Set objFSO = Nothing
Wscript.Quit(1)
End If
On Error GoTo 0
' Obtain local Time Zone bias from machine registry.
Set objShell = CreateObject("Wscript.Shell")
lngBiasKey = objShell.RegRead("HKLM\System\CurrentControlSet\Control\" _
& "TimeZoneInformation\ActiveTimeBias")
If (UCase(TypeName(lngBiasKey)) = "LONG") Then
lngTZBias = lngBiasKey
ElseIf (UCase(TypeName(lngBiasKey)) = "VARIANT()") Then
lngTZBias = 0
For k = 0 To UBound(lngBiasKey)
lngTZBias = lngTZBias + (lngBiasKey(k) * 256^k)
Next
End If
Set objShell = Nothing
' Determine DNS domain name.
Set objRootDSE = GetObject("LDAP://RootDSE")
strConfig = objRootDSE.Get("configurationNamingContext")
strDNSDomain = objRootDSE.Get("defaultNamingContext")
' Use ADO to search Active Directory.
Set adoCommand = CreateObject("ADODB.Command")
Set adoConnection = CreateObject("ADODB.Connection")
adoConnection.Provider = "ADsDSOObject"
adoConnection.Open "Active Directory Provider"
adoCommand.ActiveConnection = adoConnection
strBase = "<LDAP://" & strConfig & ">"
strFilter = "(objectClass=nTDSDSA)"
strAttributes = "AdsPath"
strQuery = strBase & ";" & strFilter & ";" & strAttributes & ";subtree"
adoCommand.CommandText = strQuery
adoCommand.Properties("Page Size") = 100
adoCommand.Properties("Timeout") = 60
adoCommand.Properties("Cache Results") = False
Set adoRecordset = adoCommand.Execute
' Enumerate parent objects of class nTDSDSA. Save Domain Controller
' AdsPaths in dynamic array arrstrDCs.
k = 0
Do Until adoRecordset.EOF
Set objDC = _
GetObject(GetObject(adoRecordset.Fields("AdsPath").Value).Parent)
ReDim Preserve arrstrDCs(k)
arrstrDCs(k) = objDC.DNSHostName
k = k + 1
adoRecordset.MoveNext
Loop
adoRecordset.Close
' Search entire domain.
For k = 0 To Ubound(arrstrDCs)
strBase = "<LDAP://" & arrstrDCs(k) & "/" & strDNSDomain & ">"
' Search for all users.
strFilter = "(&(objectCategory=person)(objectClass=user))"
' Comma delimited list of attribute values to retrieve.
strAttributes = "distinguishedName,sAMAccountName,displayName," _
& "description,userAccountControl,lastLogon,pwdLastSet"
' Construct the LDAP query.
' Run the query.
On Error GoTo 0
Wscript.Echo "Domain Controller not available: " & arrstrDCs(k)
Else
On Error GoTo 0
' Output heading line.
objFile.WriteLine """Distinguished Name"",""NT Name"",""Name""," _
& "Description"",""Flags"",""Password Last Set"",""Last Logon"""
' Enumerate the resulting recordset.
' Retrieve single-valued strings.
strDN = adoRecordset.Fields("distinguishedName").Value
' Escape any forward slash characters, "/", with the backslash
' escape character. All other characters that should be escaped are.
strDN = Replace(strDN, "/", "\/")
strNTName = adoRecordset.Fields("sAMAccountName").Value
'strDisplayName = objItem.Get("displayName").Value
strDisplayName = adoRecordset.Fields("displayName").Value
' The description attribute is multi-valued, but
' there is never more than one item in the array.
arrDesc = adoRecordset.Fields("description").Value
If IsNull(arrDesc) Then
strDesc = ""
Else
For Each strItem In arrDesc
strDesc = strItem
Next
End If
' Test bits of userAccountControl.
lngFlags = CLng(adoRecordset.Fields("userAccountControl").Value)
strFlags = GetFlags(lngFlags)
' Convert Integer8 value to date in current time zone.
Set objLastLogon = adoRecordset.Fields("lastLogon").Value
dtmLastLogon = Integer8Date(objLastLogon, lngTZBias)
Set objPwdLastSet = adoRecordset.Fields("pwdLastSet").Value
dtmPwdLastSet = Integer8Date(objPwdLastSet, lngTZBias)
' Create array of string values to display.
arrAttrValues = Array(strDN, strNTName, strDisplayName, _
strDesc, strFlags, CStr(dtmPwdLastSet), CStr(dtmLastLogon))
' Display array of values in a comma delimited line, with each
' value enclosed in quotes.
'Wscript.Echo CSVLine(arrAttrValues)
objFile.WriteLine CSVLine(arrAttrValues)
' Move to next record in recordset.
Loop
' Clean up.
adoRecordset.Close
adoConnection.Close
End If
Next
Function GetFlags(ByVal lngFlag)
' Function to test bits of userAccountControl attribute.
' Settings delimited by semicolons.
' Define bit masks.
Const ADS_UF_ACCOUNTDISABLE = &H02
Const ADS_UF_HOMEDIR_REQUIRED = &H08
Const ADS_UF_LOCKOUT = &H10
Const ADS_UF_PASSWD_NOTREQD = &H20
Const ADS_UF_PASSWD_CANT_CHANGE = &H40
Const ADS_UF_ENCRYPTED_TEXT_PASSWORD_ALLOWED = &H80
Const ADS_UF_TEMP_DUPLICATE_ACCOUNT = &H100
Const ADS_UF_NORMAL_ACCOUNT = &H200
Const ADS_UF_INTERDOMAIN_TRUST_ACCOUNT = &H800
Const ADS_UF_WORKSTATION_TRUST_ACCOUNT = &H1000
Const ADS_UF_SERVER_TRUST_ACCOUNT = &H2000
Const ADS_UF_DONT_EXPIRE_PASSWD = &H10000
Const ADS_UF_MNS_LOGON_ACCOUNT = &H20000
Const ADS_UF_SMARTCARD_REQUIRED = &H40000
Const ADS_UF_TRUSTED_FOR_DELEGATION = &H80000
Const ADS_UF_NOT_DELEGATED = &H100000
Const ADS_UF_USE_DES_KEY_ONLY = &H200000
Const ADS_UF_DONT_REQUIRE_PREAUTH = &H400000
Const ADS_UF_PASSWORD_EXPIRED = &H800000
Const ADS_UF_TRUSTED_TO_AUTHENTICATE_FOR_DELEGATION = &H1000000
GetFlags = ""
If (lngFlag And ADS_UF_ACCOUNTDISABLE) <> 0 Then
GetFlags = GetFlags & ";" & "User account disabled"
End If
If (lngFlag And ADS_UF_HOMEDIR_REQUIRED) <> 0 Then
GetFlags = GetFlags & ";" & "Home directory required"
End If
If (lngFlag And ADS_UF_LOCKOUT) <> 0 Then
GetFlags = GetFlags & ";" & "Account currently locked out"
End If
If (lngFlag And ADS_UF_PASSWD_NOTREQD) <> 0 Then
GetFlags = GetFlags & ";" & "No password required"
End If
If (lngFlag And ADS_UF_PASSWD_CANT_CHANGE) <> 0 Then
GetFlags = GetFlags & ";" & "User cannot change password"
End If
If (lngFlag And ADS_UF_ENCRYPTED_TEXT_PASSWORD_ALLOWED) <> 0 Then
GetFlags = GetFlags & ";" & "User can send an encrypted password"
End If
If (lngFlag And ADS_UF_TEMP_DUPLICATE_ACCOUNT) <> 0 Then
GetFlags = GetFlags & ";" & "Account for user in another domain
(local user account)"
End If
If (lngFlag And ADS_UF_NORMAL_ACCOUNT) <> 0 Then
GetFlags = GetFlags & ";" & "Default account for typical user"
End If
If (lngFlag And ADS_UF_INTERDOMAIN_TRUST_ACCOUNT) <> 0 Then
GetFlags = GetFlags & ";" & "A ""permit to trust"" account for a
domain that ""trusts"" other domains"
End If
If (lngFlag And ADS_UF_WORKSTATION_TRUST_ACCOUNT) <> 0 Then
GetFlags = GetFlags & ";" & "Computer account"
End If
If (lngFlag And ADS_UF_SERVER_TRUST_ACCOUNT) <> 0 Then
GetFlags = GetFlags & ";" & "Computer account for system backup
domain controller"
End If
If (lngFlag And ADS_UF_DONT_EXPIRE_PASSWD) <> 0 Then
GetFlags = GetFlags & ";" & "Password does not expire"
End If
If (lngFlag And ADS_UF_MNS_LOGON_ACCOUNT) <> 0 Then
GetFlags = GetFlags & ";" & "MNS logon account"
End If
If (lngFlag And ADS_UF_SMARTCARD_REQUIRED) <> 0 Then
GetFlags = GetFlags & ";" & "User must logon using a smart card"
End If
If (lngFlag And ADS_UF_TRUSTED_FOR_DELEGATION) <> 0 Then
GetFlags = GetFlags & ";" & "Service account under which a service
runs, trusted for Kerberos"
End If
If (lngFlag And ADS_UF_NOT_DELEGATED) <> 0 Then
GetFlags = GetFlags & ";" & "Security context will not be delegated
to a service"
End If
If (lngFlag And ADS_UF_USE_DES_KEY_ONLY) <> 0 Then
GetFlags = GetFlags & ";" & "Must use DES encryption types for keys"
End If
If (lngFlag And ADS_UF_DONT_REQUIRE_PREAUTH) <> 0 Then
GetFlags = GetFlags & ";" & "Account does not require Kerberos
preauthenication for logon"
End If
If (lngFlag And ADS_UF_PASSWORD_EXPIRED) <> 0 Then
GetFlags = GetFlags & ";" & "User password has expired"
End If
If (lngFlag And ADS_UF_TRUSTED_TO_AUTHENTICATE_FOR_DELEGATION) <> 0 Then
GetFlags = GetFlags & ";" & "Account enabled for delegation"
End If
If (Len(GetFlags) > 1) Then
GetFlags = Mid(GetFlags, 2)
End If
End Function
Function Integer8Date(ByVal objDate, ByVal lngBias)
' Function to convert Integer8 (64-bit) value to a date, adjusted for
' local time zone bias.
Dim lngAdjust, lngDate, lngHigh, lngLow
lngAdjust = lngBias
lngHigh = objDate.HighPart
lngLow = objdate.LowPart
' Account for error in IADslargeInteger property methods.
If (lngLow < 0) Then
lngHigh = lngHigh + 1
End If
If (lngHigh = 0) And (lngLow = 0) Then
lngAdjust = 0
End If
lngDate = #1/1/1601# + (((lngHigh * (2 ^ 32)) _
+ lngLow) / 600000000 - lngAdjust) / 1440
' Trap error if lngDate is ridiculously huge.
Integer8Date = CDate(lngDate)
On Error GoTo 0
Integer8Date = #1/1/1601#
End If
On Error GoTo 0
End Function
Function CSVLine(ByVal arrValues)
' Function to convert array of values into comma delimited
' values enclosed in quotes.
Dim strItem
CSVLine = ""
For Each strItem In arrValues
' Replace any embedded quotes with two quotes.
If (strItem <> "") Then
strItem = Replace(strItem, """", """" & """")
End If
' Append string values, enclosed in quotes,
' delimited by commas.
If (CSVLine = "") Then
CSVLine = """" & strItem & """"
Else
CSVLine = CSVLine & ",""" & strItem & """"
End If
Next
End Function
Wscript.Echo "Done"
Thank you,
Brian Moffitt, MCSE 2003
R
Richard Mueller [MVP]
"Brian" <Brian@xxxxxx> wrote in message
news:98615B61-CC88-44F1-9A09-363114507D66@xxxxxx
> can't
> need
> the
> description,
> of
> ' DocumentUsers.vbs
> Option Explicit
> Wscript.Quit(0)
> End If
> On Error GoTo 0
> Wscript.Quit(1)
> End If
> On Error GoTo 0
> lngTZBias = 0
> Next
> End If
> k = 0
> Set objDC = _
> k = k + 1
> Loop
> adoRecordset.Close
> ' Run the query.
> On Error GoTo 0
> Else
> On Error GoTo 0
> strDesc = ""
> Else
> strDesc = strItem
> Next
> End If
> Loop
> ' Clean up.
> adoRecordset.Close
> adoConnection.Close
> End If
> Next
> ' Define bit masks.
> GetFlags = ""
> End If
> End If
> End If
> End If
> End If
> End If
> End If
> End If
> End If
> End If
> domain controller"
> End If
> End If
> End If
> End If
> End If
> to a service"
> End If
> keys"
> End If
> End If
> End If
> Then
> End If
> End If
> End Function
> lngAdjust = lngBias
> End If
> lngAdjust = 0
> End If
> On Error GoTo 0
> End If
> On Error GoTo 0
> End Function
> Dim strItem
> CSVLine = ""
> End If
> Else
> End If
> Next
> End Function
> Wscript.Echo "Done"
> Thank you,
I have just found that on W2k3 the lastLogon attribute can be "not set". On
W2k I believe in similar situations that lastLogon will have the value 0. I
see that pwdLastSet always has a value. If pwdLastSet has never been
assigned a value, the value is 0, whether on W2k or W2k3 servers. It appears
that lastLogon is somehow different. If no value has been assigned the value
is 0 on W2k, but "not set" on W2k3. The fix is to replace this:
with the following:
On Error GoTo 0
dtmLastLogon = #1/1/1601#
Else
On Error GoTo 0
End If
For some strange reason, similar defensive code does not appear necessary
with the pwdLastSet attribute (at least in my tests).
The large issue, however, is that you are querying every DC in the domain.
This is necessary if you are retrieving lastLogon, as this attribute is not
replicated and a different value is saved on every DC. All the other
attributes are replicated. Your program will write one line to the file for
each user for each DC in the domain.
Since you got the same error I got, I assume you have at least one W2k3 DC.
If your domain is at W2k3 functional level, you should retrieve
lastLogonTimeStamp instead. The lastLogonTimeStamp attribute is replicated,
so there is no need to query every DC.
I would suggest you should run the script so it does not repeat the query on
every DC, but retrieves attribute values that are replicated. If you must
retrieve the value of an attribute that is not replicated, like lastLogon,
use a separate script. If you have 200 users and 10 DC's in your domain your
output file will have 2001 lines. Each user will have 10 lines in the file.
I still have an issue with Integer8 attributes I want to investigate
further. I want to check which attributes can be Null (or "not set") instead
of 0. The rules have apparently changed. If an Integer8 attribute can be
missing, you need to code similar to the fix above, where the possible error
is trapped. So far I have not found this necessary for pwdLastSet.
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
B
Brian
Richard,
Thank you for the response. It looks like the domain is at the W2k3
functional level so I'll try going back to an older version of the script
(which doesn't query all DCs) and see if I can return the lastLogonTimeStamp.
Otherwise I guess I'll just deal with all the duplicates (fortunately only 2
DCs and less than 500 users).
Thank you again,
Brian
> > can't
> > need
> > the
> > description,
> > of
> > ' DocumentUsers.vbs
> > Option Explicit
> > Wscript.Quit(0)
> > End If
> > On Error GoTo 0
> > Wscript.Quit(1)
> > End If
> > On Error GoTo 0
> > lngTZBias = 0
> > Next
> > End If
> > k = 0
> > Set objDC = _
> > k = k + 1
> > Loop
> > adoRecordset.Close
> > ' Run the query.
> > On Error GoTo 0
> > Else
> > On Error GoTo 0
> > strDesc = ""
> > Else
> > strDesc = strItem
> > Next
> > End If
> > Loop
> > ' Clean up.
> > adoRecordset.Close
> > adoConnection.Close
> > End If
> > Next
> > ' Define bit masks.
> > GetFlags = ""
> > End If
> > End If
> > End If
> > End If
> > End If
> > End If
> > End If
> > End If
> > End If
> > End If
> > domain controller"
> > End If
> > End If
> > End If
> > End If
> > End If
> > to a service"
> > End If
> > keys"
> > End If
> > End If
> > End If
> > Then
> > End If
> > End If
> > End Function
> > lngAdjust = lngBias
