Hidden Administrator Account
B
Barrie
I recently went through a difficult uninstall process with Adobe and their
technician had me create a new Administrator account to do this
(successfully). He did this by a process other than the regular Control
Panel|Users Accounts route but I do not remember the details. I had
previously not had to log-on because I was the only Administrator User. Now
I do and want to get rid of the Adobe-created administrator account that is
dictating this required log-on. Adobe tells me that they are only authorized
to create such accounts, not removed them!?*#$%
Can someone please tell me how to get rid of the unwanted Administrator
account?
W
William Anderson
Hi there Barrie,
I'm going off of the top of my head here as i don't have my vista laptop in
front of me.
Go to Start, Right click on My Computer and select manage. At the
Administrator prompt, click OK. Once the computer management window opens,
go to system tools, users and groups, and then users. Right click on the
Adobe created admin account and delete it.
Let me know if that works.
If your being force to log on to the Adobe created Admin account because
there are no others on the Welcome screen, try hitting CTRL+ALT+DELETE twice.
It should take you to a prompt where you can manually type it in.
Let me know if this works!
Best Regards,
> account?
B
Barrie
Thanks for the suggestion, William. I am using Vista Home Premium and the
sequence in the Computer Management window is not as you describe. I cannot
see any reference to Users and Groups.
"William Anderson" wrote:
> Hi there Barrie,
> front of me.
> Best Regards,
> > account?
T
Tom Allen
"Barrie" <Barrie@xxxxxx> wrote in message
news:1CC4B0DB-5B93-45E4-88AE-310B24149D52@xxxxxx
>their
> Control
> User. Now
> that is
> authorized
> Administrator
> account?
Try running the command 'control userpasswords2' and see if you can
knock it on the head from there.
Tom
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
account?
Hi Barrie,
It depends on which Administrator account they had you create. One like from the Control Panel - User Accounts, or they had you enable the real Built-In Administrator account.
Either way, log into your original Administrator account and not the one they had you create. If Vista starts up into this account instead of yours, then you can see how to change it to start back up in your original account in this tutorial. Just select your original Administrator account in step 5.
http://www.vistax64.com/tutorials/66966-logon-automatically.html
Look to see if the account they had you create is in User Accounts - Manage Another Account. If it is, then this tutorial will show you how to delete it.
http://www.vistax64.com/tutorials/93026-user-account-delete.html
If they had you enable the real Built-In Administrator account, then this tutorial will show you how to turn it off.
http://www.vistax64.com/tutorials/67567-administrator-account.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
B
Barrie
I had not seen that command before, Tom. It took my right to the
(apparently) relevant window but, when I tried to remove the Administrator
from the list it would not let me, even though I am on the list as well, as
an administrator. I tried changing the privileges to "User" as opposed to
"Administrator" but that still did not let me remove it.
> >their
> > Control
> > User. Now
> > that is
> > authorized
> > Administrator
> > account?
> Tom
A
Andre Da Costa[ActiveWin]
By default, the Administrator account in Windows Vista does not require a
password, its blank. The Administrator is only accessible through Safe Mode
also. You can enable the Administrator account after installation if you did
an upgrade from Windows XP. Click Start > right click Computer > click
Manage > expand Local Users and Groups > select Users > right click the
Administrator account > click Set Password. After which, you can try logging
in.
Once you have enabled Vista's "built-in" Administrator account, try logging
into it and delete the Adobe Administrator account.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry
> Now
> is
> authorized
> account?
B
Barrie
#8
Outstanding! Yes. it was a hidden Built-In administrator account that I
could not handle by the usueal Control Panel route. I followed the steps in
your tutrorial with much appreciation and success. It is extraordinary how
often the command prompt comes up trumps! Thank you so much.
"brink" wrote:
> > their
> > Now
> > that is
> > authorized
> > account?
> Hi Barrie,
> to delete it.
> Hope this helps,
> Shawn
> brink
> *There are no dumb questions, just the people that do not ask them.*
> WWW.VISTAX64.COM (\"HTTP://WWW.VISTAX64.COM\")
> *Please post feedback to help others.*
B
Barrie
#9
Thanks, Andre. YOur message arrived while I was following brink's directions
(successfully).
> in.
> Andre
> > Now
> > is
> > authorized
> > account?
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#10
"brink" wrote:
Hi Barrie,
Logon Automatically
> to delete it.
User Account - Delete
> Hope this helps,
> Shawn
Your welcome Barrie,
Glad I was able to help you resolve your problem.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
FINALLY! Thanks so much!
"brink" <brink.2ykbza@xxxxxx-mx.forums.net> wrote in message
news:brink.2ykbza@xxxxxx-mx.forums.net...
>> their
>> Now
>> that is
>> authorized
>> account?
> Hi Barrie,
> to delete it.
> Hope this helps,
> Shawn
> brink
Posted via a free Usenet account from http://www.teranews.com
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#12
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
