HKEY_LOCAL_MACHINE\BCD00000000 ?
S
SwampYankee
I see a registry key I don't recognize at HKEY_LOCAL_MACHINE, it's value is BCD00000000.
There are a few folders underneath but they don't seem to contain anything usefull
any ideas what this is?
thanks
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
thanks
Hi SwampYankee,
Quote:
The boot.ini configuration file has been replaced with Boot Configuration Data file in %SystemDrive%\Boot\BCD. This file is a registry hive (also mounted under HKEY_LOCAL_MACHINE\BCD00000000 on Windows Vista).
You can read more on it here. It is a PDF file, so you will need something like Adobe Reader installed to see it.
http://www.symantec.com/avcenter/reference/Windows_Vista_Kernel_Mode_Security.pdf
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
D
dean-dean
Well, I see value data such as Windows Boot Manager,
\system32\winresume.exe, \boot\memtest.exe, etc., among all the alphanumeric
stuff, in that key.
The XP boot.ini configuration file has been replaced with the Boot
hive (mounted under HKEY_LOCAL_MACHINE\BCD00000000 on Windows Vista). Its
contents can be viewed in a more readable form using bcdedit.exe in Command
Prompt, and the more so with programs like VistaBootPRO or EasyBCD. The data
is useful in that it's used to boot your computer...
"SwampYankee" <1@xxxxxx> wrote in message
news:MPG.2150f49d4346bfdc989695@xxxxxx
>BCD00000000.
> usefull
> thanks
S
SwampYankee
In article <#9AbhjN9HHA.464@xxxxxx>, dean-dean@xxxxxx
says...
> stuff, in that key.
> >BCD00000000.
> > usefull
> > thanks
OK, booting the computer is a good thing. I'll keep it!
Thanks, just wanted to make sure it wasn't a spyware thing.
