HKEY_LOCAL_MACHINE problem
J
Josh Roig
I run Registry Mechanic and get the two identical messages:
High Priority: Highlighted value is missing or invalid:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
Search\Gather\Windows\SystemIndex
I select the repair option, then restart the computer, run Registry Mechanic
again, and get the same two messages.
I have tried using the system restore option, trying all of my oldest
existing restore points, and I get the message that an unspecified error has
occurred and that the system files have not changed.
The big problem is that my system has become pretty slow. Restarts often
bring up an OS failure, although the automatic repair function takes the
computer back to the same slow performing system.
Does anyone have any suggestions?
Thanks.
J
Josh Roig
"Bruce Chambers" <bchambers@xxxxxx> wrote in message
news:enl74JguJHA.1208@xxxxxx
>> Mechanic again, and get the same two messages.
>> has occurred and that the system files have not changed.
>> Thanks.
> First and foremost: Stop sabotaging your system by using a snake oil
> registry "cleaner" to damage it.
> Then, try telling us precisely what problems you're having, under what
> precise circumstances they occur, along with the exact text of any and all
> error messages.
> Generically, a slow down in system performance can be caused by having too
> many unnecessary processes and/or applications running in the background,
> malware, a badly fragmented hard drive, and/or too little system resources
> (CPU power, RAM, etc.) for what you're trying to do. The one thing that
> won't cause a system to slow down is the only thing you've mistakenly and
> potentially disastrously tried to address: the alleged presence of
> extraneous registry entries.
Thanks for your advice. I've uninstalled Reg Mechanic (and also Ascentive
Performance). There has been some improvement in speed.
My program list includes the following:
CCleaner
RegCure
PCSpeedScanPro
I don't think I've used these for a long time. Should I uninstall them
anyway?
What can I do to speed up my system?
Thanks.
M
Malke
> CCleaner
> RegCure
> PCSpeedScanPro
> anyway?
Uninstall RegCure and PCSpeedScanPro. CCleaner is very useful although you
should *not* use the registry cleaning function.
The above indicates a possible hardware issue and you should do some
hardware troubleshooting, starting with the hard drive and the power
supply.
http://www.elephantboycomputers.com/page2.html#Hardware_Tshoot
Software can cause slowness as Bruce already told you. Malware, too many
processes/programs running in the background, etc. After you've determined
that the hardware is healthy (or replaced the faulty components), scan for
malware and do general maintenance.
http://www.elephantboycomputers.com/page2.html#Removing_Malware
http://aumha.org/a/loads.htm - What loads at Startup?
http://www.theeldergeek.com/services_guide.htm
http://www.blackviper.com
http://www.elephantboycomputers.com/page2.html#Maintenance
http://www3.telus.net/dandemar/slowcom.htm
http://aumha.org/a/health.htm - Take Out the Trash
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
http://www.elephantboycomputers.com/#FAQ
