How Can I get network to go Private Automatically
cincyguy
1
Hi everytime I turn XBOX on it finds it ok but always comes up as a public network.I have to manually go in and set it to Private before it will share with the PC.How can I set the XBOX (italways finds it as unspecified network) to be Private network automatically like my Internet access.Xbox it connected to PC with ethernet cable. Thanks Karl
MrNeeds
PC Geek
1,823
Location
Lymm, Cheshire, UK
you could buy a router, not an expensive one, but an ethernet switch which you can connect your xbox to it, since its always on and always connected, theres no need to fiddle with the connection settings.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
