How can I tell if a function is already defined?
K
Kevin Buchan
Maybe I'm looking at this wrong, but what I want to do is
conditionally dot source a .ps1 file if it hasn't already been loaded
earlier in my script.
I'm making use of the "Should-Process.ps1" script so that I can add
that great functionality to my own special purpose functions. Each of
these is currently maintained in separate scripts and each has a
dependency on the Should-Process.ps1 script. I'd like to just add a
line to dot source the Should-Process.ps1 file if the Should-Process
function is not already defined.
I can't seem to figure out how to tell if it is, though.
Thanks.
Kevin Buchan
B
Brandon Shell [MVP]
get-content function:<Name>
Brandon Shell
Blog: http://www.bsonposh.com/
PSH Scripts Project: www.codeplex.com/psobject
K> Maybe I'm looking at this wrong, but what I want to do is
K> conditionally dot source a .ps1 file if it hasn't already been loaded
K> earlier in my script.
K>
K> I'm making use of the "Should-Process.ps1" script so that I can add
K> that great functionality to my own special purpose functions. Each
K> of these is currently maintained in separate scripts and each has a
K> dependency on the Should-Process.ps1 script. I'd like to just add a
K> line to dot source the Should-Process.ps1 file if the Should-Process
K> function is not already defined.
K>
K> I can't seem to figure out how to tell if it is, though.
K>
K> Thanks.
K>
J
if (!(test-path function:\should-process)) {. Should-Process.ps1}
should do it.
You'd need to specify the full path to Should-Process.ps1, if it's not in
your path.
Jon
"Kevin Buchan" <kevin.buchan@xxxxxx[Pls Don't Spam]sanders.com> wrote in
message news:ml7hq39trfk79j49sjq66gdkoeefbmgfsp@xxxxxx
> Thanks.
> Kevin Buchan
K
Kevin Buchan
That's perfect!
I knew that there had to be a great solution like this, but never
considered using 'Test-Path'.
-Kevin
On Tue, 5 Feb 2008 17:54:36 -0000, "Jon"
>should do it.
>your path.
