How catch unhandled Exception in WPF Project
H
Horst Klein
I my Forms Application I catch unhandled Exceptions this way and show them
in a custom ErrorDialog:
Public Shared Sub Main()
AddHandler System.Windows.Forms.Application.ThreadException, AddressOf
OnVitoThreadError
AddHandler AppDomain.CurrentDomain.UnhandledException, AddressOf
OnVitoUnhandledError
Try
m_Application = New MyCustomApplication
m_Application.Run()
Catch ex As Exception
ErrorDialog.ShowError(ex)
End Try
End Sub
Private Shared Sub OnVitoUnhandledError(ByVal sender As Object, ByVal e As
UnhandledExceptionEventArgs)
MyErrorDialog.ShowError(ex)
If e.IsTerminating Then Environment.Exit(-1)
End Sub
Private Shared Sub OnVitoThreadError(ByVal sender As Object, ByVal e As
System.Threading.ThreadExceptionEventArgs)
LogFacade.LogCriticalError("Nicht behandelter Fehler ThreadException",
e.Exception)
MyErrorDialog.ShowError(e.Exception)
End Sub
If I do the same Sub Main in a WPF Project my Error never will shown.
What kind of Event I have to handle?
M
Mark Moeykens
You may have to work with App_DispatcherUnhandledException. I was
just reading about it today, I haven't used it yet.
Take a look at http://msdn2.microsoft.com/en-us/library/ms743714.aspx
for an example of how it's implemented. It's about half way down the
page.
You can also go here for more info:
http://msdn2.microsoft.com/en-us/li...application.dispatcherunhandledexception.aspx
On Aug 15, 8:46 am, Horst Klein <HorstKl...@discussions.microsoft.com>
> OnVitoThreadError
> Try
> m_Application.Run()
> End Try
> End Sub
> End Sub
> e.Exception)
> End Sub
H
Horst Klein
Hi Mark
Thanks a lot for your answer.
I find yesterday the DispatcherUnhandledException and build a simple project
to find a way to solfe the problem.
In my application i start a new thread to show the windows.
And I think thats the reason why it dons't work (At designtime it works. on
runtime not)
Do you know how I have to handle exceptions in thread.
See my sample project in the attachment.
Best regards
M
Mark Moeykens
I'm sorry Horst, unfortunately I don't know how to do this yet. I haven't
had a chance to play around in this area. :(
"Horst Klein" wrote:
> Hi Mark
> runtime not)
> Best regards
L
Laurent Bugnion, MVP
Salut Horst,
Du bist in der Schweiz, gäll? Wo schaffst du?
Laurent
PS: Du kannst auf diese Email Adresse antworten.
Horst Klein wrote:
> Hi Mark
> No problem
> I have open an supportrequest to the MS-Partner boys.
> To fix to Problem.
> Best regards
> Horst
Laurent Bugnion [MVP ASP.NET]
Software engineering, Blog: http://www.galasoft.ch
PhotoAlbum: http://www.galasoft.ch/pictures
Support children in Calcutta: http://www.calcutta-espoir.ch
M
Mark Moeykens
Ok great!
Be sure to post what you find out. ;)
> Hi Mark
> No problem
> To fix to Problem.
> Best regards
> Horst
