How do I disable pop up blockers and firewall programs?
D
debbie
I need to find out how to disable pop up blockers and firewall programs just
temporarily due to I am downloading programs which I purchased from a
reliable source.
Thank you ..... In need of help
M
Mark L. Ferguson
Click start, and type :
services.msc
hit enter
Turn off the Windows Firewall service.
In the IE browser, Tools menu, point at "Popup Blocker" and then check the
"Turn OFF popup blocker" item
Please use the Communities guidelines when posting.
http://www.microsoft.com/wn3/locales/help/help_en-us.htm
Use the "Ratings" feature. It helps the new users.
Mark L. Ferguson MS-MVP
https://mvp.support.microsoft.com/profile/Mark.Ferguson
"debbie" <debbie@xxxxxx> wrote in message
news:176F4E73-B20B-4757-A50E-EFF11FAD05C3@xxxxxx
> just
> reliable source.
D
debbie
Mark,
Thanks for the help! I did exactly what you said and I will check to make
sure I can dowload the programs.
Debbie
> services.msc
> hit enter
> > just
> > reliable source.
