How Do I Enable a Cascading "Breadcrumb Bar" In Explorer?
Dzomlija
Resistance is Futile
2,213
Location
South Africa
I'll admit that it originally took a little getting used to, but the new "Bradcrumb Bar" in Windows Vista Explorer is amazing.
There's just one option I'd like to see.
When clicking on the triangular icons next to each component of a folder in the Breadcrumb Bar, I'd like to have the resulting dropdown cascasde to show sub folders of those listed (similar to the way the Classic Start Menu works). Is there a way to enable this?
In the screenshots I've included, for example, if I hover the mouse over "Patches & Updates" (Screenshot 1), I'd like a sub-menu of sorts to appear that contains the folders "Applications" and "Windows Updates" (Screenshot 2).
If Vista doesn't have the facility to do this, then if anyone here is a member of the Windows Feedback Program, then could you forward this "request" to Microsoft for inclusion in Windows Seven or even for consideration as a Vista update? I can't join the WFP because it's for "US Residents Only" (Doh!), and I live in South Africa.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hi Peter,
I do not believe that is possible in Vista. The only option close to that would be in the Navigation Pane under the Folders listing.
Sorry,
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Dzomlija
2,213
Location
South Africa
Hi Peter,
Sorry,
Bummer.:cry:
Maybe if someone from Microsoft is listening, they'll make it an update, or will include it in Windows Seven?
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
