How do I get Untitled out of Notepad?
S
Sandee
Whenever I write something in Notepad and print it, the printed version
always has the word "Untitled" printed at the top. It doesn't show up on
the document until it is printed. How do I stop that from happening?
Thank you.
Sandee
A
Andre Da Costa[ActiveWin]
Use WordPad.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry
"Sandee" <Sandee@xxxxxx> wrote in message
news:7501C3E4-C68F-44A2-837C-60BE67B70D89@xxxxxx
> Thank you.
> Sandee
Dzomlija
Resistance is Futile
2,213
Location
South Africa
Thank you.
Sandee
Before printing, go to the "File->Page Setup", then clear the Header and Footer. Click OK.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
W
WaIIy
On Sun, 6 Jan 2008 21:06:00 -0800, Sandee
>Thank you.
>Sandee
First you have to save the file, but don't need to close it.
Put this in when you save it " alt-255" then print it.
Put a quotation mark, then hit alt and 255 and another quote.
You will then have to save it as a regular txt file.
Hardly worth the trouble, but it will work.
M
Michael Walraven
Sandee,
The name of a file that has not yet been given a name is 'Untitled' so one
option is to name the file (save it with a name). The other option is to not
have the file name printed at the top.
File
Page Setup
the options in the Header apply (&f is the 'file name')
Michael
Vista Home premium
> Thank you.
> Sandee
B
- Bobb -
>> on
>> Thank you.
>> Sandee
That a printer setup option:
To GET that to happen: (default)
To create a header or footer
On the File menu, click Page Setup.
In the Header or Footer box, type the letter and character combination
from the following table.
To: Insert the open file's name or (untitled) if the file has no name.
Type: &f
To: Insert the date. Type: &d
To: Insert the time specified by your computer's clock. Type: &t
To: Insert page numbers. Type: &p
To: Insert an ampersand (&). Type: &&
To: Align the header or footer to the left, center, or right. Type: &l,
&c, or &r
To have it NOT happen, change the page properties - change header/footer
/etc
Rather than "&f" etc erase that - leaving " nothing" in the field(s)
