How do i kill this thing?!?
Shaqattack
3
Hi yall umm the best way to sum this up is. I'm being trolled by this thing. i tried alot of things. and this thing limited some of my options it cut off system restore so i was out of luck, It BSOD's When i scan with Avast,Malware.SuperAnti(Although it found it delete some but afterwards it just Bsod. how? i have no clue) Avira didn't even get a chance to update During installation it Bsod me again! here the part that stumps me IT NOT DOING ANYTHING, My info wasn't stolen yet and it took me a while to realize i had this thing. My comp is moving a normal speeds (Majority of the time)And there no websites, No nothing. it literally trolling me ;-; So i thought about combofix, i heard it can destroy files to the point you have to Reinstall but i was willing to do so. i only had to save 1 folder and the rest can be deleted. it deleted a file. Not sure which, Host proccess kept failing and so does other ones Window explorer has to restart if i put 2 much stress on it. after combo fix i did a scan with avast 2 see if it still there
a couple of hours went by and i thought i finally won and it bsod me again ;-; So i had enough i installed a new os i didn't Format the Partion (Or whatever it is) i deleted it and made a new one Currently gettin drivers, and i was able to create a sysem restore point it just, i can't use it. i got scared again hoping it wasn't true and here i scanned with avast 30 mins later i got Bsod
im stumped is this even a virus?! it can't be D8
richc46
Staff member
20,105
Location
Fairfield County, CT
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
Do not use Combofix, it's a perfectly safe tool as long as you're under the instructions of a trained professional. As you said, it can do serious damage to your system if you just run it without supervision.
I'm sure Rich will be able to get you back up and running in no time :) I just wanted to say that about Combofix
Can you do the following for me please?
OTL
Download OTL to your desktop.
Double click on the icon to run it. Make sure all other windows are closed to let it run uninterrupted.
When the window appears, underneath Output at the top change it to Minimal Output.
Under the Standard Registry box change it to All.
Check the boxes beside LOP Check and Purity Check.
Click the Run Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL.
Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post it with your next reply.
I am currently doing a malware removal degree so I will not be able to help you at this time, but I would really appreciate it if you could make this log for me please - I'm trying to familiarise myself with these logs. I will be able to tell you if you're infected or not, but nothing else :)
Thanks,
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
