How do i reset my video card?
Unk75
74
Location
Romania
Hi i want to reset my video card settings but i don't know how....
I have a Intel 945 Express chipset family
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
stoneys-nutz
Gamerholic
2,685
Location
Wale's
Hello Unk75,
Can you explain what you mean by "reset", do you want to set it back to its default condition ?, if so, just un-install and re-install the drivers, that should take it back to factory settings.
Hope this helps, good luck and post your results.
    Self Build
    QX9650 (black box) 3.0GHz@3.9GHz
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Unk75
74
Location
Romania
Still doesn't work :(. Here's exactly how my screen looks like and i want to fix it:
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
derekimo
Staff member
784
Location
Shasta County
Have you tried adjusting it from control panel, appearance and personalization, adjust screen resolution?
Also what happens when you click apply on that screen you posted?
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    250GB Samsung 850 EVO SSD
    1TB WD Blue
    1TB Hitachi
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Laptop specs: HP g7-1365dx /
    CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics /
    RAM: Crucial 8Gb (2x4Gb) /
    SSD: Crucial M4-CT128M4SSD2 ATA Device/ FW 000F /
    GFX: AMD Radeon HD 6520G /
    OS: Windows 10 Pro x64
Unk75
74
Location
Romania
No. Is still not working. It happens on boot menu too: my screen shows only in left part. :(
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
Unk75
74
Location
Romania
And by the way, my display is like that since i got computer crashed by ntkrnlpa.exe in windows 7, and i forgot to restore my system and i deleted the old windows folder.
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
stoneys-nutz
Gamerholic
2,685
Location
Wale's
Have you tried adjusting the "monitor" and not the graphics ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
stoneys-nutz
Gamerholic
2,685
Location
Wale's
#9
On your monitor (normally on the bottom), you will find a row of buttons, these alter the position of the display. Have a play around with these and see if you can adjust the position of the screen.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
derekimo
Staff member
784
Location
Shasta County
#13
You have Vista listed as your OS, But above you are saying you're computer crashed by ntkrnlpa.exe in windows 7. Is this a fresh install of Vista?
From what I can find about crashes related to ntkrnlpa.exe, Most recommendations are a repair install but some more detailed info from you would help us help you.
You might want to try this just to see if it helps,
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
Remember to run as administator when open command.
Let us know the outcome.
Derek
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
Unk75
74
Location
Romania
#14
This seems to work, idk. I will try it after school.
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
Unk75
74
Location
Romania
#15
So, 1 month ago i got computer crashed by ntkrnlpa.exe and then my screen was like in the images below. I then installed windows vista, and then back again to windows 7. The screen not fixed, below all this, in the boot menu, it shows me the windows vista boot screen, not the windows 7 boot screen. I deleted all old windows files. Still not fixed. And sorry for my bad english. I hope someone will translate this lol.
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
derekimo
Staff member
784
Location
Shasta County
#16
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
derekimo
Staff member
784
Location
Shasta County
#17
Your english is good, I am just trying to get as much info as I can so that we can help you get this fixed.
I noticed you are using the Windows 7 RC in your screenshots. Since that is starting to shut down every 2 hours now to start phasing it out, I would suggest going back to Vista if you don't have a retail copy of Windows 7.
Do you have the Vista installation DVD?
Also if you could fill out some of your system specs, Computer make and model number. This little program will help you with the specifics if you need,http://www.piriform.com/speccy
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
Unk75
74
Location
Romania
#18
Operating system - MS Windows 7 Ultimate 32-bit
CPU - Intel Mobile Core 2 Duo T5200 @ 1.60GHz 58 °C Merom 65nm Technology
RAM - 2.0GB Dual-Channel DDR2 @ 266MHz 4-4-4-12
Motherboard - Hewlett-Packard 30D5 (U10)
Graphics - Digital Flat Panel (1024x768 60Hz) on Mobile Intel 945 Express Chipset Family
Mobile Intel(R) 945 Express Chipset Family
Hard Drives - 250GB SAMSUNG SAMSUNG HM251JI ATA Device (IDE)
Optical Drives - TSSTcorp CDDVDW TS-L632H ATA Device
Audio - Conexant High Definition Audio
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
Unk75
74
Location
Romania
#19
Still don't work man :( I think my video card is screwed or something because i scanned vista for errors and found nothing :( :( :( :(
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
derekimo
Staff member
784
Location
Shasta County
#20
OK Since you are still talking about Vista and you listed Windows 7 above, Is this a dual boot?
You might try this,
http://www.vistax64.com/tutorials/78545-directx-diagnostic-tool.html?ltr=D
Also in device manager under your display adapter, if you right click and select properties does it say this device is working properly?
Run that diagnostic tool above and let us know how that turns out.
Can you also clarify if you are running both Vista and Windows 7.
Thanks,
Derek
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
