How do I uninstall Sonic DLA?
A
astro999
I have just upgraded to Windows Vista Ultimate and can't uninstall Sonic
DLA.I did run the Vista advisor and it told me that it might have some minor
compatibillty issues after upgrading to Vista.So now its doesn't work and I
cant find how to remove it from my Vista Ultimate OS system so i can put in
the new Sonic one thats compatable.Does anyone have any ideas as how to fix
this?
Thank you
astro999
R
Richard Urban
You uninstall Sonic DLA prior to upgrading your computer. Why? Because the
entire application that installed it (likely some version of Roxio) is not
Vista compatible.
I ended up reinstalling Vista to get rid of it. It hooks deeply into the
operating system internals and is not easy to manually remove.
Regards,
Richard Urban
Quote from George Ankner:
If you knew as much as you think you know,
You would realize that you don't know what you thought you knew!
"astro999" <[email protected]> wrote in message
news:[email protected]
> minor
> I
> in
> fix
> this?
> Thank you
> astro999
Hey Astro,
I bought a new pc that had it preinstalled so I ended up uninstalling it
because I don't need to burn cds on that pc... figure I can reinstall it
later when I do need it. Anyways, what I found is that there were about 5 or
6 roxio programs but if I remember correctly you can just delete the one
program that does the drag and drop cd burning and the rest should work
fine.
I found out that tip after I already removed the program so it's worth a
shot.
A
astro999
David thanks for the info about the 90 day support.I went to Roxio's web site
and they are aware of this problem,people get a driver not compatable message
and they are working on this matter.However they say the cause is a Microsoft
Update (KB929427) and if you just remove it for the time being you wont get
the annoying message, and I did that and it works.But I really dont want to
do a clean install but I may have to,because I have already bought the Vista
compatable Roxio Easy Media Creator 9.I also did get the Sonic DLA
uninstalled just by removing the Windows update,but the rest of the program
is still there,and wont uninstall.WOW what a mess this Vista has been so
far.I can install that update later after its fixed.
Thank you
astro999
"David F" wrote:
> You are best off doing a fresh install which is what I did. Otherwise, call
> up either Lenovo or Microsoft. With Microsoft Retail Vista has 90 free
> telephone and email support.
> "Rob" <[email protected]> wrote in message
> > Oh, and by delete, I mean uninstall.
Visit the Roxio web site, they have an uninstaller and info on what to
delete from the Registry.
Leo
When I was young and adventurous, I wanted to join a violent,
armed group with no regard for the law, but the IRS wasn't hiring.
A
astro999
#8
David, Do you know the telephone number for support and or e-mail support?
Thank you
astro999
T
Tony1976
#9
try this:
http://support.dell.com/support/top.../dsn/en/document?c=us&docid=315789&l=en&s=gen
> this?
> Thank you
> astro999
P
Puppy Breath
#10
My advice is, don't. It's probably not written for Vista and you don't need
it anyway because you can all the same stuff in Vista withoug installing
DLA. If you install DLA you'll probably just create a world of headaches for
yourself and lose all the built-in CD and DVD burning capabilities.
Learn how to do CDs and DVDs in Vista and forget about all those old XP
programs.
"Tony1976" <[email protected]> wrote in message
> try this:
>> minor
>> I
>> in
>> fix
>> this?
>> Thank you
>> astro999
W
William
#11
Simply go to Control Panel\Programs & Features then Uninstall Roxio Drag &
Drop. That will clear up that Sonic error message everyone's been getting.
> try this:
>> minor
>> I
>> in
>> fix
>> this?
>> Thank you
>> astro999
R
Richard Urban
#12
I installed it and it works fine with Vista.
Regards,
Richard Urban
"Puppy Breath" <[email protected]> wrote in message
> need it anyway because you can all the same stuff in Vista withoug
> installing DLA. If you install DLA you'll probably just create a world of
> headaches for yourself and lose all the built-in CD and DVD burning
> capabilities.
> programs.
> news:[email protected].
>> try this:
>>> minor
>>> and I
>>> in
>>> fix
>>> this?
>>> Thank you
>>> astro999
P
PRNole
#13
Which version Sonic DLA are you using with Vista?
I use v4.95 for my HP and it has always worked great with my XP (and
98 before that). I got it as a download patch from HP support.
However, the Vista advisor program I ran to see what components might
be incompatible w/Vista suggested I uninstall my DLA prior to
installing any Vista version.
I haven't installed Vista yet, for I'm trying to figure out how to do
a dual install of both Business and Home Premium versions on my hdd (I
know I have to create a partition), but...I would like to keep some
version of Sonic DLA since it works great for my purposes.
I've not seen any Vista dedicated Sonic DLA version at the HP website
yet.
On Mar 2, 11:21 am, "Richard Urban"
> Regards,
> Richard Urban
> > capabilities.
> > programs.
> >> try this:
> >>http://support.dell.com/support/topics/global.aspx/support/dsn/en/doc...
> >>> minor
> >>> and I
> >>> in
> >>> fix
> >>> this?
> >>> Thank you
> >>> astro999
R
Richard Urban
#14
Erh! The one from the Dell site - the one we are discussing here. It's on my
computer right now as a stand alone application.
Regards,
Richard Urban
"PRNole" <[email protected]> wrote in message
> yet.
>> Regards,
>> Richard Urban
>> > of
>> > capabilities.
>> > programs.
>> >> try this:
>> >>> Sonic
>> >>> some
>> >>> minor
>> >>> and I
>> >>> put
>> >>> in
>> >>> to
>> >>> fix
>> >>> this?
>> >>> Thank you
>> >>> astro999
P
PRNole
#15
Sorry...didn't see any reference to Dell or any other OEM.
Nevertheless, my Sonic DLA is also a stand alone version and works
with various other OEMs (ie., my daughter's Gateway notebook and
wife's Sony desktop). Is your DLA that works with your Vista a Dell-
dedicated app? Even if it is, do you know the version? I might be
willing to try it in with my son's Vista Ultimate on his HP.
Thanks!
On Mar 2, 2:34 pm, "Richard Urban"
> Regards,
> Richard Urban
> > yet.
> >> Regards,
> >> Richard Urban
> >> > of
> >> > capabilities.
> >> > programs.
> >> >> try this:
> >> >>> Sonic
> >> >>> some
> >> >>> minor
> >> >>> and I
> >> >>> put
> >> >>> in
> >> >>> to
> >> >>> fix
> >> >>> this?
> >> >>> Thank you
> >> >>> astro999
R
Richard Urban
#16
Made by Roxio, available on the Dell web site - as the apps that Dell ships
have problems.
Regards,
Richard Urban
> Thanks!
>> my
>> Regards,
>> Richard Urban
>> > yet.
>> >> Regards,
>> >> Richard Urban
>> >> > don't
>> >> > world
>> >> > of
>> >> > capabilities.
>> >> > XP
>> >> > programs.
>> >> >> try this:
>> >> >>> Sonic
>> >> >>> some
>> >> >>> minor
>> >> >>> work
>> >> >>> and I
>> >> >>> can
>> >> >>> put
>> >> >>> in
>> >> >>> how
>> >> >>> to
>> >> >>> fix
>> >> >>> this?
>> >> >>> Thank you
>> >> >>> astro999
