How long does System Restore take?
L
Lang Murphy
Doing a system restore and it appears to be hung on the "Windows is
preparing to shut down..." blue/green swirly screen... HD light has been
pegged, with minimal flickering, for close to 20 minutes now... that seems a
bit long...
A
Andre Da Costa [Extended64]
System Restore usually takes the same amount of time as a restart of
Windows.
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"Lang Murphy" <[email protected]> wrote in message
news:%[email protected]
> a bit long...
H
Henry
Sounds like it's not working correctly, what number beta are you using. most
of the early ones didn't. I did a restore on 5384.4 and it worked.
> a bit long...
L
Lang Murphy
Well... it took about 30 minutes, but I finally got the log on screen... but
getting error that system restore did not complete successfully... no
changes to files and settings... bummer.
> a bit long...
L
Lang Murphy
5384... and it didn't work... sigh...
"Henry" <[email protected]> wrote in message
news:O9F%[email protected]
> most of the early ones didn't. I did a restore on 5384.4 and it worked.
>> seems a bit long...
T
Tony Sperling
I did this once in x64, it took 30 minutes to establish that the restore
point didn't work. I kept on picking dates further back in time and each
time it took 30 minutes, but when it finally hit a date that worked it took
less than 20 sec's.
Tony. . .
news:[email protected]
> but getting error that system restore did not complete successfully... no
>> seems a bit long...
