How much of a session does start-transcript capture?
A
Andrew Watt [MVP]
I did a simple test to see whether start-transcript could help with
the recently posted question about XCopy.
To my surprise,
start-transcript
XCopy C:\NonExistent.txt C:\NotHere.txt /C
stop-transcript
showed the error message from XCopy on the console but didn't capture
it in the transcript.
Since the Help file for start-transcript states that "the entire
session" will be copied to the transcript file that is a
disappointment and concern.
Is the failure to capture error information from XCopy "by design" or
a bug?
Thanks
Andrew Watt MVP
Author - Professional Windows PowerShell (Wrox)
D
DBMwS
I was able to see that even after redirecting error output to standard output
Here is the transcript file
Windows PowerShell Transcript Start
Start time: 20060522100203
Username : ..
Machine : ..
Transcript started, output file is ./test.txt
[^_^]PS[217]>XCopy C:\NonExistent.txt C:\NotHere.txt /C 2>&1
XCOPY.EXE : File not found - NonExistent.txt
At line:1 char:6
+ XCopy <<<< C:\NonExistent.txt C:\NotHere.txt /C 2>&1
[^_^]PS[218]>Stop-Transcript
Windows PowerShell Transcript End
End time: 20060522100235
But below is what i really typed.
[^_^]PS[216]>Start-Transcript ./test.txt
0 File(s) copied
At line:1 char:6
Transcript stopped, output file is C:\programming\ps\transcripts\test.txt
[^_^]PS[219]>ii test.txt
Apparently, "0 File(s) copied" is not displayed in transcript file "test.txt".
> To my surprise,
> start-transcript
> stop-transcript
> a bug?
> Thanks
> Andrew Watt MVP
