Solved How to add more space to my Vista partition
ingeborgdot
Pain In The Butt
Power User
86
Location
Scott City, Kansas
I am running vista 64 and want to add more space to my os partition. I have my hdd partitioned to dual boot XP(which I don't really use anymore) and Vista Ultimate 64 bit. I then have documents etc on the other partition with about another 400GB of space left. I have had to add some more things to my vista os and with sp1 and sp2 coming out shortly I would like to add some more of my unused space to it. What programs do people use for vista on this? Thanks.
    Genuine Home Built Grad A
    Q6600
    Abit IP35Pro
    4GB Crucial Ballistix
    VisionTek Radeon HD4850
    HT Omega Claro
    Sansung SyncMaster 2493HM
    1900x1200
    2 - internal seagate 500GB
    1 - external 2TB NDAS server
    P&C quad 750 watt
    Antec P182
    6016kbps
lordbob75
Lord of Bobs
Vista Pro
1,676
Location
In my Fortress
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
SIW2
2,741
Depending on what you are trying to, you may find Vista Disk Management too limited.
A lot of us use Paragon Partition Manager 9 -works great on Vista x64 and on Windows Seven.
Paragon Partition Manager – resize partitions, partitioning software
If you are looking for a free alternative you could try this - tho. you will probably need to do a startup repair when you've finished
Using GParted to Resize Your Windows Vista Partition :: the How-To Geek
here's the direct d/l for a tiny free isoburner - works great , just runs straight away - I use to burn iso to cd all the time
http://www.ntfs.com/downloads/Iso-burner.zip
This is the version of Gparted I have used - direct d/l
http://downloads.sourceforge.net/gparted/gparted-0.4.1.tar.bz2?modtime=1227957187&big_mirror=0
Hope it helps
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
ingeborgdot
Pain In The Butt
Power User
86
Location
Scott City, Kansas
What I find is that the extend partition for the vista os is not able to be selected.
    Q6600
    Abit IP35Pro
    HT Omega Claro
    1900x1200
    P&C quad 750 watt
    Antec P182
    6016kbps
lordbob75
Lord of Bobs
Vista Pro
1,676
Location
In my Fortress
Can you delete your old partition and just create a new one for your Vista install? This would create a second "drive" (like drive D:\) but would still give you more space.
I know you want to have one bigger partition, but that solution would work about the same....
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
rive0108
2,081
Location
Hampton Roads, Virginia, USA
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    640GB 7200RPM SATA/RAID 0 (2x320GB)
    and 320GB 7200RPM External
    Wireless Microsoft 3000
    10 mbps/2 mbps
    Optical Drive:
    Panasonic UJ-220 DL BD-RE (Blu-Ray)
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi ingeborgdot,
Exactly how is your disk currently partitioned?
Brink said:
WARNING
  • You will not lose any data on the partition (volume) that you are Extending. The partition you want to delete and use to extend another partion must be to the immediate right of the one you want to extend. You can cannot extend a partition from a deleted partition two or more partions to the right of it.
  • All data on a partition will be lost when you Delete it. Be sure to back up any files that you want to save to a different location before you continue.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
SIW2
2,741
#8
I have not had a problem with it.
If you wish to move system files on the System partition - rather than just shrinking free space - use the bootable disc it will create for you.
Afaik this is the case with any partition manager.
Hope it helps
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
rive0108
2,081
Location
#9
Hope it helps
SIW2
I attached the bootable disk ISO (recovery media builder), so there is no need to install Paragon. Just burn the DVD/Floppy disk for the partitioning software in linked thread above, then Merely shrink/create/delete/expand partition(s). Simple and easy.
Here is a walkthrough on how to remove Dual Boot:
http://www.ehow.com/how_4405638_remove-dual-boot-vista.html
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
SIW2
2,741
#10
Hi Ingeborgdot,
Vista Disk Management will only extend to the right ( in Disk Management view ).
Could you post a screenshot of the Disk Management window please ?
Thanks
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
ingeborgdot
Pain In The Butt
Power User
86
Location
Scott City, Kansas
#11
Here is a screen shot that you wanted.
    Q6600
    Abit IP35Pro
    HT Omega Claro
    1900x1200
    P&C quad 750 watt
    Antec P182
    6016kbps
SIW2
2,741
#12
The simplest way to add more space to your Vista drive is to take space from the Music drive on it's right.
1. Defrag the E drive - Vista's defrag will be very slow - d/l the free Auslogics program and use that - it could still take awhile depending how badly fragmented it is.
Disk Defrag - Reclaim the Speed Of Your Disks
2. In Disk Manangement, right click the E drive and select Shrink - this will tell you how much you can shrink it by.
If you are lucky, it will be 230gb or more. Shrink it by the max it allows. You now have unallocated space of that size ( black bar across the top ).
3. Right click the new unallocated space and select New simple Volume , it will suggest a drive letter ( probably H which will be fine ) also select Quick Format.
When the format is finished, Restart the pc. You now have another partition ( it will be green in Disk Management, which means an extended partition - don't worry about that , it's fine for storing data )
4. In Explorer ( not disk management ) copy the entire contents of the E drive to the new drive, H. That will take a while. Check it has all copied across to your satisfaction.
5. You can now go into Disk Management, right click the E drive and select Delete. This will now be unallocated space.
6. Right click the C drive and select extend to incorporate all that unallocated space into a much larger C drive.
Hope it helps
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
ingeborgdot
Pain In The Butt
Power User
86
Location
Scott City, Kansas
#13
I see what you are saying. This is very interesting and I do still have some more questions before I start.
Will I be able to get my drive E back with the name E.
I just want to make my c drive another 50 GB or so not much more than that unless you think there is a need to have it larger.
Drive E is now 110GB full. Let's see if I have this straight though. I will shrink it as much as I can. I will select New simple volume and whatever letter is suggests with a quick format. Copy entire contents to new drive letter and check. Go into disk management and delete E. Go into C and extend. Simple.
Questions though. This means that my C will now be 110GB larger. Can I go in an move some stuff over to another drive for now and make it smaller so that when I do this my E will be only about 50GB or so? I think I may have some more questions before I do this but thanks soooo much for your time so far. I really appreciate it.
    Q6600
    Abit IP35Pro
    HT Omega Claro
    1900x1200
    P&C quad 750 watt
    Antec P182
    6016kbps
delphin
Eager to learn
Vista Pro
636
Location
Chennai
#14
U can use the extend partition option in vista. The only thing is if u want to icrease the os partition u should delete all the other partition except the os partition.
Step1- back up data in all other partitions usin externel hard disk(or u can copy those files in to ur os partition also).
Step2- delete all other partitions,
Step3- extend the os partition using extend partition option,
Step4- create partitions and restore ur datas.
Let me know the result
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
SIW2
2,741
#15
Hi I ngeborgdot,
Sure, you can make a folder on another drive, move some (70 -80gb ) , or all of the contents of your E drive on there. There's plenty of space on your backup G drive for that.
You will be able to Shrink E much further, make a bigger new partition H - and be left with a smaller E.
You will be able to delete that smaller E , then extend C to include that now smaller unallocated space.
You could Rename the H to E as that letter is not being used.
It would take along time to shift all that music to another drive and then onto the new partition , of course.
Hope it helps
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
SIW2
2,741
#16
There is another way to do it.
Use a bootable partition manager - either Linux Gparted, or the Dos one Echrada posted earlier may be simpler -( make sure your mouse is installed in a ps/2 port as some don't support usb mouse connections ).
It gives a window somewhat similar to Disk Management.
You then grab hold of the left edge of the partition you want to shrink, and drag it 50gb to the right. Press Apply or Next, and wait ( a long time, an hour at least )- it will move that 100gb of music data 50gb across to the right.
You will then have that 50gb unallocated space between the C drive and the smaller E drive.
Then use Vista Disk Management to extend the C partition to incorporate the 50gb unallocated space.
Hope it helps
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
ingeborgdot
Pain In The Butt
Power User
86
Location
Scott City, Kansas
#17
What if I would get rid of everything in the E drive and move it to my G. That would take a lot less time than doing with Gparted. Then do the Gparted move. When done add all the stuff back to the E drive.
    Q6600
    Abit IP35Pro
    HT Omega Claro
    1900x1200
    P&C quad 750 watt
    Antec P182
    6016kbps
lordbob75
Lord of Bobs
Vista Pro
1,676
Location
In my Fortress
#18
That would work.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
SIW2
2,741
#19
If you are going to move everything from E onto G - that would be fine.
You wouldn't then need Gparted.
1. After you have moved /copied all from E onto G, go into Disk Management and rt click and delete E.
2. Rt click C and Extend another 50gb.
3. Rt click the remaining unallocated space, create New Simple Volume, assign letter E, select Quick Format. When done, restart.
All you need to do then is copy/move your Music from G back to the new E.
That is very simple, but moving all your Music twice will take a long while.
Hope it helps
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
ingeborgdot
Pain In The Butt
Power User
86
Location
Scott City, Kansas
#20
All done. Worked great. Thanks for the help.
    Q6600
    Abit IP35Pro
    HT Omega Claro
    1900x1200
    P&C quad 750 watt
    Antec P182
    6016kbps
