how to check available ports?
R
Robert L. \(MS-MVP\)
This may help.
How to find open ports on a computer
You can use PULIST from the Windows Resource Kit to find which process
is using a specified port. For example, pulist |find /i "4125" may display
www.howtonetworking.com/command/openport1.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"process" <circularfunc@xxxxxx> wrote in message
news:209071cf-b835-4fcb-9105-3dc54d5c9126@xxxxxx
> how can I check available ports on my computer?
J
Jack \(MVP-Networking\).
Hi
You have to be specific and explain what do you need the port for?
If it is an Hardware port look at the the computer's hardware manual.
If it is a network port. There are about 64000 ports most of them are
available, the choice is usually done according to the application that
needs the port.
Jack (MS, MVP-Networking)
