How to close explorer.exe which I never opened?
P. Jayant
31
Every time I shut down Vista, in the process of closing on the black screen, I see a message saying: The following programs are still running:. And just below, is the name explorer.exe.
The message appears, even if I have meticulously closed all the programs and there is no mention of explorer on the taskbar; stranger still – the message appears even if I shut downVista, immediately after opening it, for test purpose.
How does one get this quirky behaviour of Vista corrected? Or does explorer.exe open on its own in Vista? And what does one do to close an application which does not show up on the taskbar as open?
P. Jayant
Dzomlija
Resistance is Futile
2,213
Location
South Africa
P. Jayant
EXPLORER.EXE is an integral part of Windows, and does indeed start automatically when you log on, and in turn initializes such visual elements as the taskbar itself, and the desktop.
What is causing it to stutter and interfere with the shutdown process, is likely some type of installed extension that is crashing. This could be just about anything, but likely suspects are such things as copy handlers that usually intercept the standard copy/paste functions. Older versions of Nero Scout (designed for XP) have also been known to wreak havoc with Explorer in Vista.
Do you perchance recall installing any software prior to this error occuring?
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
R
R. McCarty
Explorer.Exe is Windows Shell ( What you see and work with ). Just
as Internet Explorer has Add-ons, Explorer's capabilities are expanded
by programs that add Shell Extensions. These are things like the Right
Click entries for "Scan for Viruses with..." Most times when Explorer
has issues shutting down for reboot/turn-off it's due to these extensions.
One program that helps in finding 3rd-party extensions is:
http://www.nirsoft.net/utils/shexview.html
"P. Jayant" <P.Jayant.34rmv1@xxxxxx-mx.forums.net> wrote in message
news:P.Jayant.34rmv1@xxxxxx-mx.forums.net...
> *Every time I shut down Vista, in the process of closing on the black
> running:. And just below, is the name explorer.exe.*
> *The message appears, even if I have meticulously closed all the
> still - the message appears even if I shut downVista, immediately after
> opening it, for test purpose.*
> *How does one get this quirky behaviour of Vista corrected? Or does
> application which does not show up on the taskbar as open?*
> *P. Jayant*
> P. Jayant
P. Jayant
31
Pretty lame excuse. If Explorer is a part of Windows and is going to remain open as long as Windows is Open as a part of the Windows Shell, why give a false signal to the User saying : "Some Programs (specifically explorer.exe) are still running"?
P. Jayant
koch
Power User
94
P. Jayant,
Please do the following:
1. Press the ctrl-alt-delete keys at the same time
2. You will see screen with a list of options with arrows on the left
3. Click the "Start Task Manager" option
4. The Windows Task Manager window will appear
5. There are six tabs at the top (Applications, Processes, Services, Performance, etc.)
6. Select the "Processes" tab
7. Find "explorer.exe" under the column heading "Image Name"
8. Right click on "explorer.exe" and then left click on "End Process"
Now do you see why you need this process running?
Sometimes a demonstration is needed to get the point across.
Dzomlija
2,213
Location
South Africa
P. Jayant
Maybe you should read all the posts to a thread before you make funny remarks. EXPLORER.EXE is required by Windows, as the demonstration by Koch will show.
EXPLORER.EXE can and will hang the shutdown process if a badly written shell extension crashes...
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
