how to create an association in set association control panel
C
crazygirl
Help, I have read all of the questions and answers regarding how to do this
but still do not know how to create. I am a beginner and need step by step
instructions. I have went into my control panel and then into
programs/default and that brought up a screen with names such Windows email
on the left side of the screen and then at the bottom of the screen were two
items listed which I have now forgotten what was listed; however, I clicked
on both of them and found nothing to indicate what to do or where to go to
next so please can you give me step by step instructions.
All I am trying to do is open an attachment to an email and I receive the
message I need to create an association in set association control panel.
Thank you for taking the time to help a girl who is going crazy trying to
figure out how to do this.
J
John Barnett MVP
What type of file are you trying to open i.e., Word, PowerPoint, Excel, or
something else?
John Barnett MVP
Windows XP Associate Expert
Windows Desktop Experience
Web: http://www.winuser.co.uk
Web: http://xphelpandsupport.mvps.org
Web: http://vistasupport.mvps.org
Web: http://www.silversurfer-guide.com
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
"crazygirl" <crazygirl@xxxxxx> wrote in message
news:C72D7528-675D-418F-BDD3-F8DFA3DDE286@xxxxxx
> this
> step
> email
> two
> clicked
H
Hal Hostetler [MVP-P/I]
What kind of attachment? The program used to open an attachment depends
entirely on what kind of file the attachment is, I.E. a Word document
requires Word, a spreadsheet requires Excel, a picture might require one of
several different programs depending on what kind of picture file it is
(.jpg, or .bmp, or .gif, or whatever). If you have a Word or PowerPoint
attachment, there are some ready made fixes for these.
Hal
Hal Hostetler, CPBE
Senior Engineer/MIS -- MS MVP-Print/Imaging -- WA7BGX
www.kvoa.com -- KVOA Television, Tucson, AZ.
Live at Hot Licks - www.badnewsbluesband.comcom
> this
> step
> email
> two
> clicked
R
Rainald Taesler
CHUCKELMON wrote:
> I am trying to open WMV attachments and I get a message that I need
> Set Association
Just do so ;-)
Control Panel | Standard programs |
Rainald
R
Rainald Taesler
xyerichehy wrote:
> Hi, I HAD SAME PROBLEM IT WAS DRIVING ME NUTS,I RESET INTERNET
> EXPLORER
> TOOLS,INTERNET OPTIONS ADVANCED TAB AND RESET hope this helps:)
Thanks fro sharing your recipe.
In future pls avoid to write with UPPER CASE ONLY.
In the world if e-communications this means SHOUTING.
And it's really bad to read.
Rainald
R
Rainald Taesler
#9
xyerichehy wrote:
> hi rainald,
> wasn't aware
Thanks for the reply.
Normal UPPER and lower case mixture is the standard.
Right now you fell into the other extreme ;-) ;-)
Rainald
H
#10
Z
zillahsunshine
#11
I allowed my computer to do an automatic update with Windows, now my
hubby cannot play his Spider Solitaire. It was installed on computer
when purchased, and I don't know how to get it to open again. Says I
need to set up an association control something. What do I do? thanks
for your help.
zillahsunshine
zillahsunshine's Profile: http://forums.techarena.in/members/142781.htm
View this thread: http://forums.techarena.in/windows-vista-mail/1147323.htm
S
Steve Cochran
#12
Its possible the shortcut got damaged. The path to the game is:
"c:\ProgramFiles\Microsoft Games\SpiderSolitaire\SpiderSolitaire.exe"
steve
"zillahsunshine" <zillahsunshine.3ztund@newsgroup> wrote in message
news:zillahsunshine.3ztund@newsgroup
> for your help.
> zillahsunshine
> View this thread:
