How To: Create Dynamic Variable Names in Scripts
B
Brandon Shell
Goal:
I want to create x number of groups. These groups will have a list of
servers. I split these servers in groups by name. What I would like is for
this function to be dynamic. I hope the example will make my goal clear.
Example:
This is a very simple example... I am looking at creating 40+ groups... it
gets to be ALOT of duplicate code.
# This is what works now
Function Create-Groups {
param([system.array]$servers)
# this is where I would like to be more dynamic
$list1 = @()
$list2 = @()
$list3 = @()
$list4 = @()
$list5 = @()
foreach($server in $servers) {
if ($Server -match ".*ver1.$") {$list1 += $server}
elseif($Server -match ".*ver2.$") {$list2 += $server}
elseif($Server -match ".*ver3.$") {$list3 += $server}
elseif($Server -match ".*ver4.$") {$list4 += $server}
elseif($Server -match ".*ver5.$") {$list5 += $server}
# This is where I would like to be more dynamic
$global:group1 = $list1
$global:group2 = $list2
$global:group3 = $list3
$global:group4 = $list4
$global:group5 = $list5
Problem:
Now if I wanted to make 10 groups instead of 5... I have create 5 more
arrays and global variables. I would like to do something like:
# this of course fails... is there a way I can do this?
$i = 1
while($i -lt 21) {
$list$i = @()
++$i
=?Utf-8?B?U3VuZyBNIEtpbQ==?=
> $i = 1
> while($i -lt 21) {
> $list$i = @()
> ++$i
You can use "Invoke-Expression" cmdlet to create variables dynamially
foreach ($i in (1..21)) {
Invoke-Expression ('$`{list' + $i + '`} = @()')
Have fun~
Sung M Kim
Please don''t bother me with spam...
B
Brandon Shell
Thanks
"Sung M Kim" <SungMKim@discussions.microsoft.com> wrote in message
news:0A7D67F1-A612-46C3-A7CC-A5075012EFB0@microsoft.com...
>> $i = 1
>> while($i -lt 21) {
>> $list$i = @()
>> ++$i
> Have fun~
> Sung M Kim
=?Utf-8?B?Um9tYW4gS3V6bWlu?=
Yes, it is possible, but I would double think before using this approach. I
am just curious, why not to use, say, global hash tables with keys like
'ver1.$', 'ver2.$', etc. for servers, lists etc.?
Thanks,
Roman
B
Brandon Shell
Because I want to pipe the list to functions.
Example:
group1 | Check-Something | fix-problem
"Roman Kuzmin" <RomanKuzmin@discussions.microsoft.com> wrote in message
news:EDCBA044-6C0B-4361-96CC-37961F4B6589@microsoft.com...
> I
> Thanks,
> Roman
I definitely do not criticize.
Suppose your lists are in a hash $groups with keys like 1, 2, ‘ver5.$’ and
etc. For any <key>, i.e. group, you can do this:
$group[<key>] | Check-Something | fix-problem
No problem. For example if you want to process 3 groups 1, 2, ‘ver5.$’:
1, 2, ‘ver5.$’ | % {$group[$_]} | Check-Something | fix-problem
Suppose now a list of groups for a particular task is defined as an array
$ToDo; it is as easy as before:
$ToDo | % {$group[$_]} | Check-Something | fix-problem
Do you know how to do the same with your approach? If you know the answer
and like it then this approach is good for you.
Thanks,
Roman
A
Adam Milazzo
Brandon Shell wrote:
> Goal:
I wouldn't use invoke-expression. It's somewhat ugly.
I'd use the cmdlets designed for the purpose: new-variable,
set-variable, and get-variable (nv, sv, and gv).
nv "var.$foo"
sv "var.$foo" "value $i"
gv "var.$foo"
In place of string interpolation, you can use subexpressions:
nv ("var." + $nextVar)
You can also specify the value at creation time:
nv name value
-- Adam
J
Jouko Kynsijärvi
#8
>> $i = 1
>> while($i -lt 21) {
>> $list$i = @()
>> ++$i
Another, simpler, way is to use the new-variable cmdlet:
new-variable "list$i" @()
B
Brandon Shell
#9
I will take a look. You way does have some potential. My only concern is
that most of scripts are wrappers for people... that... hmmm... are less
than brilliant.
Im trying to keep the input as little and brainless as possible.
news:165DEFC0-FACA-4258-A531-A44ADE1FD1E6@microsoft.com...
> Suppose your lists are in a hash $groups with keys like 1, 2, 'ver5.$' and
> No problem. For example if you want to process 3 groups 1, 2, 'ver5.$':
> 1, 2, 'ver5.$' | % {$group[$_]} | Check-Something | fix-problem
> Thanks,
> Roman
#10
That's brilliant ;)
This is the second time that I overlooked "*-Variable" cmdlets... as was the
case when I needed to create a constant variable ;p
Sung M Kim
#11
> than brilliant.
I agree. But, IMO, for those people it is more natural to operate with
*names* (of groups), not *variables* (associated with groups). Thus, scripts
(wrappers for those people) should be designed to take group names as input.
Moreover in outside world there are names only. If you are about to run your
script from cmd - what are you going to pass there as input/arguments?
Besides, group names are arbitrary, variable names are not (not so easy).
How are you planning to iterate through all currently defined groups?
Get-Variable group* | …? Then:
*) ‘Names’ of you groups are forced to be like groupX (+ limitations for
‘normal’ variable names);
*) You have to take care of not using variables $groupX for other purposes.
Finally, do not forget that number of variables is limited by
$MaximumVariableCount. You are going to use at least 40 of them; perhaps it
is not too much for this particular task but for other tasks with ‘dynamic
variable names’ this approach may be also painful just because of this
limitation.
Thanks,
Roman
B
Brandon Shell
#12
I used names. We (my group) organize our servers (300+) into groups for
maintainance. My goal is to create Global variables for each group. My
delima is as we add more and more servers the number of groups change. I
would like to set one variable (the counter) and re-run the script to
add/subtract groups as needed. For my purpose having groups named $group'x'
is acceptable.
Example: I tell Joe OPS, "Hey, Can you do an App Check on Group 3?" He says
"Sure." All he has to do is:
PS> $group3 | AppCheck-Run
Server30 [PASSED]
Server31 [PASSED]
Server32 [FAILED]
Server33 [PASSED]
All Joe OPS has got to give me is the results. Then I say... "Can you
Publish Group 3." $group3 | Publish-Server
I do appreciate your suggestion and actually all the feedback you give on
these forums.
p.s. Thanks for reminding me about the variable limit... I did completely
forget about that.
news:8B5EE29A-314B-4B07-9B1B-8FA071C0BE13@microsoft.com...
>> than brilliant.
> scripts
> input.
> your
> Get-Variable group* | .? Then:
> *) 'Names' of you groups are forced to be like groupX (+ limitations for
> 'normal' variable names);
> purposes.
> it
> is not too much for this particular task but for other tasks with 'dynamic
> variable names' this approach may be also painful just because of this
> limitation.
> Thanks,
> Roman
