How to delete items in start up menu
A
How do I delete skype, msn messenger, aol im etc from starting up when the
computer initially reboots? It is slowing down my computer from loading and
driving me nuts....
I do not want to remove these items but I just want to use the icons on the
desktop IF I want to start them up..
In addition, whatever you tell me to do...do I need to do this for EACH
person's separate name that uses the computer...????
HELP!
Thanks!
N
Neil Harley
> driving me nuts....
> HELP!
> Thanks!
Type msconfig in the Start Search entry box and on the'Startup' tab
remove the apps you don't want running
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
driving me nuts....
HELP!
Thanks!
Hi Andy,
I would first look at each program's settings to disable the "Start when Windows starts" option. Most programs will give you the option. It usually depends on what type of program it is on whether you will have to do it for each user account. Some are universal (EX: Antivirus), while others are not. You can use this as a guide on how to remove them from startup.
http://www.vistax64.com/tutorials/79612-startup-programs-enable-disable.html
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
