how to delete & rename file in vbs without using WMI class
W
williamkow
Can you advise me on how to delete a file and then rename a file using vbs,
but without using WMI class. Many thanks in advance.
set fsoA = WScript.CreateObject("Scripting.FileSystemObject")
set fsoB = WScript.CreateObject("Scripting.FileSystemObject")
set fsoC = WScript.CreateObject("Scripting.FileSystemObject")
set ifile1 = fsoA.OpenTextFile("C:\DATA\INdata.txt", 1, False)
set ofile1 = fsoB.CreateTextFile("C:\DATA\OUTFILE1.txt", True)
set ofile2 = fsoC.CreateTextFile("C:\DATA\OUTFILE2.txt", True)
If ofile1.FileExists(inFile) Then
'..... read the ifile1, then processing, output to ofile1 and ofile2
ofile1.writeline ....
ofile2.writeline ....
End If
' how to delete the INdata.txt
' how to rename the OUTFILE2.txt to INdata.txt
ifile1.Close
ofile1.close
ofile2.close
P
Pegasus [MVP]
"williamkow" <[email protected]> wrote in message
news:[email protected]
> vbs,
> End If
> ifile1.Close
> ofile1.close
> ofile2.close
You can use the Delete and the MoveFile methods of the File System Object.
Download the helpfile script56.chm from the Microsoft site to see the exact
syntax and some examples.
P
Paul Randall
"Dave "Crash" Dummy" <[email protected]> wrote in message
>> vbs, but without using WMI class. Many thanks in advance.
>> End If
>> ' how to rename the OUTFILE2.txt to INdata.txt ifile1.Close
>> ofile1.close
>> ofile2.close
> First of all, you only need one File System Object. Then, after all files
> are closed,
> fso.deleteFile "C:\DATA\INdata.txt"
> fso.MoveFile "C:\DATA\OUTFILE2.txt","C:\DATA\INdata.txt"
Besides fso.MoveFile, you can also use something like:
ofile2.name = "INdata.txt"
The scripting help file says this about the name property:
Sets or returns the name of a specified file or folder. Read/write.
object.Name [= newname]
-Paul Randall
P
Paul Randall
>>>> End If
>>>> ofile1.close
>>>> ofile2.close
>>> files are closed,
> Not quite. You have set the file as an object, first:
> set oFile=fso.getFile("OUTFILE2.txt")
> oFile.name="INdata.txt"
Are you saying that after:
and before:
that:
won't work?
-Paul Randall
D
Dave \Crash\ Dummy
> and before:
> that:
> won't work?
Yes. You are confusing a TextStream object with a File object.
http://msdn.microsoft.com/en-us/library/312a5kbt(VS.85).aspx
http://msdn.microsoft.com/en-us/library/1ft05taf(VS.85).aspx
Crash
"It's easier to ask forgiveness than it is to get permission."
~ Grace Hopper (RADM, USNR) ~
P
Paul Randall
>> and before:
>>>>>> ofile2.close
>> that:
>> won't work?
> Crash
You are right. I should have refreshed my memory from the scripting help
file. Thanks for correcting me.
-Paul Randall
