how to encrypt a paswd in a file to be used for batch
F
Frank
Can someone help me in encrypting a password in a file so that I can use it
to execute batch jobs which require username/password? I have the following
script working but it seems to not work as time progresses:
$pass = read-host -assecurestring -prompt "Enter password to encrypt: "
convertfrom-securestring $pass -key (1..16) > encrypt.file
Then I use this to decrypt it:
$tt = ConvertTo-SecureString -key (1..16) (gc "./encrypt.file")
$ptr = [System.Runtime.InteropServices.Marshal]::SecureStringToBSTR($tt)
$pass_back = [System.Runtime.InteropServices.Marshal]::PtrToStringAuto($ptr)
write-output "password decrpyted is: $pass_back"
J
Jeff
What exactly happens "as time progresses"? I don't know if this will
help or not, but you might want to be sure your encoding is consistent
when you write and read the file. You will have to use Out-File
rather than redirection to create the file:
convertfrom-securestring $pass -key (1..16) |
Out-File -FilePath encrypt.file -Encoding ASCII
$tt = ConvertTo-SecureString -key (1..16) `
(Get-Content "./encrypt.file" -Encoding ASCII)
$ptr =
$pass_back =
Jeff
F
Frank
Hi Jeff,
When I decrypt it, I get the correct password string back but after about an
hour, I get "???????" back. Let me retry the test.
Thanks,
> $ptr =
> $pass_back =
> Jeff
F
Frank
ok, I think I know the problem. It appears that the key has something to do
with my login session. If I go to another PowerShell Term, I cannot decrypt
the password with the same script, if I go back to the original PowerShell
Term where I created the encrypted password, it does work. I must of used
another Term yesterday when it did not work and probably has nothing to do
with time. Can you think of a way around this?
Thanks,
> $ptr =
> $pass_back =
> Jeff
M
Marco Shaw [MVP]
> Thanks,
>> $ptr =
>> $pass_back =
>> Jeff
There's no way around this using the above method, the person encrypting
must be the person decrypting.
If you need to hide information, see the thread "securing ps scripts"
from November 1st for some ideas.
Marco
Microsoft MVP - Windows PowerShell
http://www.microsoft.com/mvp
PowerGadgets MVP
http://www.powergadgets.com/mvp
Blog:
http://marcoshaw.blogspot.com
