How to execute dos cmds in the prompt opened using VBScript?
A
AuHuman
Dim shell
Dim oExec
Set shell = CreateObject("wscript.shell")
Set oExec = shell.Exec("cmd.exe")
oExec.StdIn.Write("exit")
oExec.StdIn.Write VbCrLf
Do While oExec.Status = 0
WScript.Sleep 100
Loop
WScript.Echo oExec.Status
Above code is not executing the exit command in the command prompt opened by
shell.Exec("cmd.exe").
Nothing is happening until i close the prompt manually by clicking the close
button.
How to execute dos commands in the prompt opened by shell.Exec("cmd.exe") ?.
[i looked into the msdn library but its not clearing my above doubt]
T
Tom Lavedas
On Jan 26, 3:09 pm, AuHuman <AuHu...@newsgroup> wrote:
> Dim shell
> Dim oExec
> WScript.Sleep 100
> Loop
> Above code is not executing the exit command in the command prompt openedby
> button.
> How to execute dos commands in the prompt opened by shell.Exec("cmd.exe")?.
This worked for me ...
Dim shell, oExec
Const delay = 5
Set oExec = shell.Exec("cmd.exe /k echo Will close in " & delay & "
second(s)>con")
for n = delay to 1 step - 1
WScript.Sleep 1000
oExec.StdIn.Writeline "echo " & n & " > con"
Next
oExec.StdIn.Writeline "echo Closing > con"
WScript.Sleep 1000
oExec.StdIn.Writeline "exit"
_____________________
Tom Lavedas
A
AuHuman
Thanks a lot Tom Lavedas. Your post showed me the right way of resolving the
error i was facing.
> > Dim shell
> > Dim oExec
> > WScript.Sleep 100
> > Loop
> > button.
> Dim shell, oExec
> Const delay = 5
> second(s)>con")
> WScript.Sleep 1000
> Next
> WScript.Sleep 1000
> Tom Lavedas
M
mr_unreliable
Suggest using:
Set oExec = shell.Exec("%comspec% /k echo Will (blah, blah,.. )
instead of:
Set oExec = shell.Exec("cmd.exe /k echo Will (blah, blah,.. )
cheers, nitpickers anonymous
T
Tom Lavedas
On Jan 31, 11:58 am, mr_unreliable
> Suggest using:
> instead of:
A nit picking Win98 user. I wonder how many of you there are
left ;^))
I always use COMSPEC, myself, but chose to stick with the formulation
used by the OP in this case.
Tom Lavedas
