How to format partition with Vista installed on it?
Cypress
2
I've performed the recovery procedure on my notebook and installed Vista Home Premium 32 bit from the recovery partition. After a while I installed also Vista Ultimate 64 bit on other partition creating dual-boot. Now I want to uninstall the 32 bit OS and I don't know how. I booted on the 64 bit OS ( C: and tried to format the partition on which the 32 bit OS is installed ( D:, but within the disk management the "Format" command can't be accessed. Thanks in advance for every advice.
PS: The C: and D: partitions are on separate hard-disks.
mansrm81
1,884
Location
Rockford, IL
If they are separate go into computer and right click on the drive and select format.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
418
When setting up the dual boot the 32bit edition's primary was made the default boot partition in the process! You can't reformat the boot partition while being in the OS that loads from it without seeing that type of message come up.
The fast and easy solution would be booting from the Vista 64bit disk you used and using the reformat option while booted live from the Vista dvd. The need to see the 64bit BCD rebuilt will then be the next step since the present installation will then no longer boot up.
Solution?
1)You can nuke the 32bit primary entirely leaving a vacant space and move the 64bit primary to the front to see that expanded with a need to rebuild.
2)Or you can see a clean install on the first with a reformat of the second in mind to avoid two copies of the 64bit edition. That will leave a second for storage available.
3)The third option is simply deletion of both for a brand new single large primary using up the entire drive.
You can opt the first to leave the present intact but spend time moving it forward to expand after and follow the rebuild BCD information outlined at How to use the Bootrec.exe tool in the Windows Recovery Environment to troubleshoot and repair startup issues in Windows Vista The other option available for seeing that problem solved in found in the sticky on performing a repair install of Vista. http://www.vistax64.com/tutorials/88236-repair-install-vista.html
    Custom built desktops =2 Toshiba replace HP laptop
    AMD Phenom II X4 975 Deneb core 3.6ghz
    Gigabyte GA-790XTA-UD4
    Kingston Hyper X 1.5v DDR3 PC12800 1600mhz 16gb
    MSI Radeon HD 5750 1tb
    Creative X-Fi XtremeAudio PCIe
    Asus 19" HP 20" second lcd main HP 20" remote pc.
    1440x900, 1600x900 main - 1600x900 2nd desktop
    WD Black Edition 1tb Sata II -2
    WD SAS "Heavy Duty" RE class 2tb - 2
    External usb/eSata WD Black 1tb main -1
    External usb only WD Green Power 1tb -1
    Corsair 750w 750TX main - Corsair 600w remote
    Antec 900-2 - SSD compatible eSata ports 2 - NZXT Vulcan 2nd
    Zalman CNPS9900A cpu, twin front 120s, top 200cm, rear 120
    MSI Interceptor D200
    AZIO Ilumminated keys gaming keyboard/volume control usb
    30mbps upgrade
