How to handle spaces in command line paths?
X
xformer
Hello,
I installed PowerShell to automate some tasks. I only write scripts and
stumled upon the following "feature": When a script is located in a directory
that has spaces in it I can't get PowerShell to execute the script. It always
stops parsing after the first space character.
Example: A script named "task.ps1" is located in "E:\All Batch Scripts\".
If I open a Windows explorer and double-click on the file. It doesn't work.
If I open a PowerShell and enter "E:\All Batch Scripts\task" it doesn't work
and shows the following message:
The expression "E:\All" was not recognized as a cmdlet, function, executable
program or script file. Check the expression and try again.
At Line:1 Character:7
+ E:\All <<<< Batch Scripts\task
If I put the script path into double or single quotes PowerShell just echoes
it.
I can get it to work by putting the path parts that contain spaces in single
quotes but that is not a general way to handle path names that contain spaces.
So my question is: What do I have to do so that PowerShell executes scripts
which have a path that contains spaces?
And the second question is how to put that in a link file in the autostart
directory so that the script is started whenever the user logs on?
Any help would be greatly appreciated.
Frank
J
John Vottero
Start with a & and enclose in quotes like this:
C:\> &"C:\My PowerShell Scripts\Check Disks.ps1"
"xformer" <xformer@discussions.microsoft.com> wrote in message
news:7E81A0C4-3C27-49D8-8590-CC7C55AF492A@microsoft.com...
> Hello,
> directory
> always
> work.
> work
> executable
> echoes
> it.
> single
> spaces.
> scripts
> Frank
R
RichS
To run a script in that manner try
&"c:\test three\test3.ps1"
& tells Powershell to execute the string rather than just echoing it
back. if you need parameters etc put them oustide the quotes
your command is
%SystemRoot%\system32\WindowsPowerShell\v1.0\powershell.exe -command
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
Blog: http://richardsiddaway.spaces.live.com/
PowerShell User Group: http://www.get-psuguk.org.uk
"xformer" wrote:
> Hello,
> it.
> Frank
