how to make virtual guests to see 2 nic cards ?
I
IT STAFF
1. hyper-v 2008 r2
2. physical host contains 2 physical nic cards
3. set one nic cards for "external" use in hyper-v
4. created 2 virtual guests using "internal" network.
5. How can i make the virtual guests see "2 nic cards" ?
C
Charlie Russel - MVP
You need to create networks. The choices are External, Internal, or Private.
Read the descriptions to understand the differences. Then go to the
Settings for each VM and add a second network card, and map it to a network.
If you are running an older, legacy operating system,, or one that doesn't
have Integration Components (ICs) available, you'll need to add Legacy
Network Adapters, not Network Adapters. These are lower performance emulated
NICs, but ones that virtually all OS's have drivers for.
Charlie.
http://msmvps.com/blogs/russel
"IT STAFF" <[email protected]> wrote in message
news:[email protected]
> 1. hyper-v 2008 r2
