How to map openssl obtained private key parameters to RSAParameters struct members?
S
SammyBar
Hi all,
I need to fill a System.Security.Cryptography.RSAParameters structure with
my private key parameters. The private key is in PEM format so by using
openssl I can obtain all the parameters. But openssl names the parameters
different to the RSAParameters struct. The openssl output is in the form
openssl rsa -in key.pem -noout -text
modulus: ...
publicExponent: ...
privateExponent: ...
prime1: ...
prime2: ...
exponent1: ...
exponent2: ...
coefficient: ...
How these map to the RSAParameters membersD, DP, DQ, Exponent, InverseQ,
Modulus, P y Q?
Thanks in advance
Sammy
C
Claudio
RE: How to map openssl obtained private key parameters to RSAParameter
Hi Sammy,
version Version,
modulus INTEGER, n
publicExponent INTEGER, e
privateExponent INTEGER, d
prime1 INTEGER, p
prime2 INTEGER, q
exponent1 INTEGER, d mod (p-1)
exponent2 INTEGER, d mod (q-1)
coefficient INTEGER, (inverse of q) mod p
C.
"SammyBar" wrote:
> Hi all,
> modulus: ...
> publicExponent: ...
> prime1: ...
> prime2: ...
> exponent1: ...
> exponent2: ...
> coefficient: ...
> Modulus, P y Q?
> Thanks in advance
> Sammy
