How to position the PowerShell window on screen?
M
Marc Scheuner
Folks,
Another potentially embarrassing and stupid question: how can I add
some Powershell magic lines of code to my profile so that the
PowerShell window appears in the bottom right hand corner of my
screen? (preferably these lines should be so smart as to deal with
various screen resolutions, too - on my notebook and my 24" desktop
screen, for instance).
I looked at various properties of $Host, $Host.UI, $Host.UI.RawUI, but
couldn't really figure out anything that seemed to make sense......
Thanks for any hints and pointers!
Marc
J
Jeff
On Jan 23, 1:03 pm, Marc Scheuner <[email protected]> wrote:
> Folks,
> Marc
Marc,
I decided to work out a way to do this, but I have to warn you that
this isn't exactly a simple solution. This is one of those situations
that I hope someone else out there has a much easier way of doing
this. I ended up using Win32 API functions through some C# code that
I compile at run-time. I tried to make the Window functions fairly
general in case you might have any other uses for them.
This creates an assembly in your $home directory that contains the
compiled C# code. The complexity of this solution comes from needing
to account for where the taskbar is, and whether or not its "Auto-
hide" setting is set.
Here you go. I hope at least you have a good laugh over it.
# Move-Window
$cSharpCodeProvider = `
New-Object Microsoft.CSharp.CSharpCodeProvider
$parameters = `
New-Object System.CodeDom.Compiler.CompilerParameters
$parameters.GenerateInMemory = $true
$parameters.GenerateExecutable = $false
$parameters.OutputAssembly = "Custom.dll"
# create a strongly-named assembly
$cr = $cSharpCodeProvider.CompileAssemblyFromSource( $parameters,
using System;
using System.Runtime.InteropServices;
namespace Win32Api
public class WindowSizeUtilities
private enum ApplicationBarMessage : int
GetState = 4,
GetTaskBarPosition = 5
private enum ApplicationBarState : int
Manual,
AutoHide,
AlwaysOnTop,
AutoHideAndOnTop,
public enum ApplicationBarEdge : int
Left,
Top,
Right,
Bottom
[StructLayout(LayoutKind.Sequential)]
private struct ApplicationBarData
public int Size;
public IntPtr Handle;
public int CallbackMessage;
public ApplicationBarEdge Edge;
public Rectangle Rectangle;
public IntPtr Param;
public struct Rectangle
public int X;
public int Y;
public int Left;
public int Bottom;
[DllImport("shell32")]
static extern uint SHAppBarMessage(
ApplicationBarMessage dwMessage,
ref ApplicationBarData pData );
[DllImport("user32.dll")]
public static extern bool GetWindowRect(
IntPtr hWnd,
out Rectangle rectangle );
public static extern int SetWindowPos(
IntPtr hWnd,
IntPtr hWndInsertAfter,
int x,
int y,
int cx,
int cy,
uint uFlags );
public static void GetTaskBarPosition(
ref bool autoHide,
ref ApplicationBarEdge edge,
ref int x,
ref int y,
ref int width,
ref int height )
ApplicationBarData applicationBarData =
new ApplicationBarData();
uint result =
SHAppBarMessage(
ApplicationBarMessage.GetState,
ref applicationBarData );
switch ( (ApplicationBarState)result )
case ApplicationBarState.Manual:
case ApplicationBarState.AlwaysOnTop:
autoHide = false;
break;
case ApplicationBarState.AutoHide:
case ApplicationBarState.AutoHideAndOnTop:
autoHide = true;
break;
default:
autoHide = false;
break;
SHAppBarMessage(
ApplicationBarMessage.GetTaskBarPosition,
edge = applicationBarData.Edge;
x = applicationBarData.Rectangle.X;
y = applicationBarData.Rectangle.Y;
width = applicationBarData.Rectangle.Left -
height = applicationBarData.Rectangle.Bottom -
public static void GetWindowPosition(
IntPtr hWnd,
ref int x,
ref int y,
ref int width,
ref int height )
Rectangle windowRectangle = new Rectangle();
GetWindowRect( hWnd, out windowRectangle );
x = windowRectangle.X;
y = windowRectangle.Y;
width = windowRectangle.Left - windowRectangle.X;
height = windowRectangle.Bottom - windowRectangle.X;
public static void SetWindowPosition(
IntPtr hWnd,
int x,
int y,
int width,
int height,
uint uFlags )
SetWindowPos(
hWnd,
(IntPtr)null,
x, y,
width, height,
(uint)uFlags );
$taskbarAutoHide = $false
$taskbarEdge = 0
$taskbarX = 0
$taskbarY = 0
$taskbarWidth = 0
$taskbarHeight = 0
# get the taskbar position information
[Win32Api.WindowSizeUtilities]::GetTaskBarPosition(
[ref]$taskbarAutoHide,
[ref]$taskbarEdge,
[ref]$taskbarX,
[ref]$taskbarY,
[ref]$taskbarWidth,
[ref]$taskbarHeight )
# get the PowerShell window handle
$powershellHandle = ( Get-Process "powershell" ).MainWindowHandle
$powershellX = 0
$powershellY = 0
$powershellWidth = 0
$powershellHeight = 0
# get the position of the PowerShell window
[Win32Api.WindowSizeUtilities]::GetWindowPosition(
$powershellHandle,
[ref]$powershellX,
[ref]$powershellY,
[ref]$powershellWidth,
[ref]$powershellHeight )
# get the primary monitor information
$screen = [System.Windows.Forms.Screen]::PrimaryScreen
# work out the new position
$newX = 0
$newY = 0
# convert to int for easier comparison
# Left = 0
# Top = 1
# Right = 2
# Bottom = 3
$taskbarEdge = [int]$taskbarEdge
if ( !$taskbarAutoHide -and
( $taskbarEdge -eq 2 -or $taskbarEdge -eq 3 ) )
if ( $taskbarEdge -eq 2 )
$newX = $screen.Bounds.Width -
$powershellWidth -
$taskbarWidth
$newY = $screen.Bounds.Height -
$powershellHeight
else
$powershellWidth
$powershellHeight -
$taskbarHeight
else
$newX = $screen.Bounds.Width - $powershellWidth
$newY = $screen.Bounds.Height - $powershellHeight
# move the window!
[Win32Api.WindowSizeUtilities]::SetWindowPosition(
$powershellHandle,
$newX,
$newY,
-1, # cx
-1, # cy
0x0001 # SWP_NOSIZE - retains the current size -
# ignores the width and height parameters
Have fun!
Jeff Hillman
J
Jeff
> > Folks,
> > Marc
> Marc,
> # Move-Window
> $parameters = `
> using System;
> namespace Win32Api
> GetState = 4,
> Manual,
> AutoHide,
> AlwaysOnTop,
> AutoHideAndOnTop,
> Left,
> Top,
> Right,
> Bottom
> public int Size;
> public int X;
> public int Y;
> public int Left;
> public int Bottom;
> IntPtr hWnd,
> IntPtr hWnd,
> int x,
> int y,
> int cx,
> int cy,
> uint uFlags );
> ref bool autoHide,
> ref int x,
> ref int y,
> ref int width,
> ref int height )
> uint result =
> SHAppBarMessage(
> autoHide = false;
> break;
> autoHide = true;
> break;
> default:
> autoHide = false;
> break;
> SHAppBarMessage(
> IntPtr hWnd,
> ref int x,
> ref int y,
> ref int width,
> ref int height )
> IntPtr hWnd,
> int x,
> int y,
> int width,
> int height,
> uint uFlags )
> SetWindowPos(
> hWnd,
> (IntPtr)null,
> x, y,
> width, height,
> (uint)uFlags );
> $taskbarEdge = 0
> $taskbarX = 0
> $taskbarY = 0
> $taskbarWidth = 0
> $taskbarHeight = 0
> [ref]$taskbarEdge,
> [ref]$taskbarX,
> [ref]$taskbarY,
> [ref]$taskbarWidth,
> $powershellX = 0
> $powershellY = 0
> $powershellHandle,
> [ref]$powershellX,
> [ref]$powershellY,
> $newX = 0
> $newY = 0
> # Left = 0
> # Top = 1
> # Right = 2
> # Bottom = 3
> $powershellWidth -
> $taskbarWidth
> $powershellHeight
> else
> $powershellWidth
> $powershellHeight -
> $taskbarHeight
> else
> # move the window!
> $powershellHandle,
> $newX,
> $newY,
> -1, # cx
> -1, # cy
> Have fun!
> Jeff Hillman
One more thing. The following line only works right if you only have
one instance of PowerShell running:
Jeff
M
Marco Shaw [MVP]
Marc Scheuner wrote:
> Folks,
> Marc
If you'd consider adding a snap-in to do this:
http://www.codeplex.com/WASP
Marco
Microsoft MVP - Windows PowerShell
http://www.microsoft.com/mvp
PowerGadgets MVP
http://www.powergadgets.com/mvp
Blog:
http://marcoshaw.blogspot.com
M
Marc Scheuner
Hi Jeff,
Yes, indeed - that's surprisingly complex - hmm.... have I found the
first "spot" in PowerShell where it does not really solve a "common"
problem with a simple one-liner? :-) Is that still the same in V2 ??
If so, maybe the PowerShell team needs to take notice for the v3 time
frame to add some simple PowerShell commands to size and position its
own window on screen! :-)
Thanks for your effort - highly appreciated !
Marc
K
Karl Prosser[MVP]
Dealing with the console is a complex thing.
Powershell Plus has extended the console significantly with resize,
screenbuffer size, font , transparency, hotkeys etc. IT has exposed also
exposed a lot of that functionality through the $psplus variable where
you as a scripter can change those attributes. If there is a
functionality that we have exposed to the script through the $psplus
variable, we can easily add it.
-Karl
http://www.powershell.com
> Hi Jeff,
> Marc
