how to remove shadow on icon fonts
H
Hello
How can I remove the shadow on the fonts in icons on the desktop ? Thank
you.
hash
J
It's in Performance Options, Vistal effects tab. This is the long way
there... why it's not more easily accessible is a mystery.
Control Panel--System and Maintenance--Performance Info tools--Use tools to
improve performance--Advanced tools--Adjust Appearance and performance of
windows. Uncheck the dropshadow for icon labels. But be warned, the type is
only a white color. So if you have a light background it's hard to read.
Amazinf we cant set the desktop font color!!
"hash" <joeblogg@spam.com> wrote in message
news:uBtWK9L2HHA.5380@TK2MSFTNGP04.phx.gbl...
> Hello
> you.
> hash
D
David
Not correct. While you can't CHOOSE the font color, the font will
switch to black if the background is a light color.
Dave
P
Purpleman
The best solution with maximum flexibility is to install Iconoid. It`s a
great little free programme that has some very useful facilities. Works fine
on Vista as well. Just google the word Iconoid.
"brink" wrote:
> hash;412510 Wrote:
> > Hello
> > Thank
> > you.
> > hash
> Hi Hash,
> If you would like some screenshots with those instructions by John, see
> the link.
> http://www.vistax64.com/tutorials/75417-visual-effects-options.html
> Shawn
> brink
> *There are no dumb questions, just the people that do not ask them.*
> _http://www.vistax64.com/ (\"http://www.vistax64.com/\")_
> *Please post feedback to help others.*
Brink
Staff member
mvp
Hi Purpleman,
Thank you for the Iconoid suggestion. It looks like a neat little program. Do you know if it works in x64 Vista as well? I did not see Vista listed in the supported OS list, so I am just assuming that it may only work in x32 Vista. ??
P
Purpleman
Hi. I don`t know as I have x32 system. It wouldn`t hurt to try it. If it
doesn`t work properly, just unistall it and delete it`s programme folder etc.
> > fine
> Hi Purpleman,
> Shawn
> brink
> _http://www.Vistax64.com (\"http://www.Vistax64.com\")_
Brink
Staff member
mvp
#8
Purpleman,
Well I gave Iconoid a try, but it would not run for the x64 Vista. It did install and uninstall without any problems though. (haha) Oh well, perhaps one day they will make a x64 version.
Thank you anyway,
