How To Safely Remove Recovery Partition?
alex96
I recently installed Windows 7, but due to performance issues, I had to revert back to Vista. The F11 key was disabled because I upgraded, so I used a Vista Installer and inputed my serial code on my machine. Anyway, I created generic Recovery Discs, so I do not need my old unusable Recovery Partition any more. Is there any sort of way to safely remove it, and extend my C drive for more space?
BTW, I don't have HP Recovery Manager so, I cannot use the 'Delete Recovery Partition' feature on there.
Hello alex96.
In the Windows start menu right click computer and choose manage, in the left pane select disk management, in disk management if the "D: Recovery Partition" is directly to the right of the "C: System" partition you can use the tutorial at the link below to do what you want; please post back to keep us informed.
Be advised: once it's gone it's gone forever.
http://www.vistax64.com/tutorials/95418-disk-management-delete-extend.html?ltr=D
If it's not post a snip of disk management so we can see what you have.
A Preferred Method of Uploading/Posting Screen Shots - Windows 7 Forums
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
Please post a complete snip of disk management so we can see what you have.
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
