How to Skip comment in text - GC file.txt
T
techstarts
I have below file called servers.txt
#Hostnames should be lower caps
Server1
Server2
Server3
#Server4
Server5
I would like to put some comment in the text file which powershell
should skip it. is it possible. e.g. I do not want powershell to read
anything which starts with #
Thank you in Advance
V
Vadims Podans [MVP]
gc servers | ?{$_ -notmatch "^#"}
WBR, Vadims Podans
MVP: PowerShell
PowerShell blog - www.sysadmins.lv
<techstarts@xxxxxx> rakstija zinojuma
"news:a852e49f-3c62-4dc2-b41c-9c3d0587ffad@xxxxxx"...
> Server1
> Server2
> Server3
> #Server4
> Server5
T
techstarts
> WBR, Vadims Podans
> MVP: PowerShell
> PowerShell blog -www.sysadmins.lv
> <techsta...@xxxxxx> rakstija zinojuma
> "news:a852e49f-3c62-4dc2-b41c-9c3d0587ffad@xxxxxx"....
> > Server1
> > Server2
> > Server3
> > #Server4
> > Server5
Again thank you very much. Problem solved.
Do I know what ^ does ?
V
Vadims Podans [MVP]
^ means that pattern must match at string begining.
WBR, Vadims Podans
MVP: PowerShell
"news:96452047-f04c-48a8-a198-4a5d8c0900f8@xxxxxx"...
>> WBR, Vadims Podans
>> MVP: PowerShell
>> > Server1
>> > Server2
>> > Server3
>> > #Server4
>> > Server5
U
Umesh Thakur
alternatively,
gc servers | Where-Object {$_.StartsWith("#") -eq $false}
should work too
Umesh
"Old programmers never die. They just terminate and stay resident."
> WBR, Vadims Podans
> MVP: PowerShell
> >> WBR, Vadims Podans
> >> MVP: PowerShell
> >> > Server1
> >> > Server2
> >> > Server3
> >> > #Server4
> >> > Server5
O
OldDog
> You should.
> At least after having read:
>    get-help about_regular_expressions
> or the online version
>    http://go.microsoft.com/fwlink/?LinkId=133231
> Regards
> Matthias
^ Matches the beginning "book" -match "^bo"
characters
And it's get-help about_regular_expression ' No s at the end.
J
Josh Einstein
#8
I figured I'd mention you could do it in one command with select-string...
select-string '^(?!#)' file.txt
<techstarts@xxxxxx> wrote in message
> Server1
> Server2
> Server3
> #Server4
> Server5
M
Matthias Tacke
#9
Well to be unambiguous
get-help about_reg
is sufficient,
but PowerShell V2 from Windows 7 where I copied the whole line from has the
s at the end.
Regards
Matthias
