How to start/stop services on Vista?
  • Thread starter Siegfried Heintze
  • Start date
S
Siegfried Heintze
OK, I'm embarassed. I cannot find the UI for managing services. Can someone
tell me what the sequence of mouse/key clicks from the start menu?
Thanks,
Siegfried
D
Dominic Payer
Press Control - Shift - Escape together. Vista has reverted to the
NT4/Windows 2000 key combination.
"Siegfried Heintze" <siegfried@heintze.com> wrote in message
news:uJpjSTe1HHA.4916@TK2MSFTNGP03.phx.gbl...
> someone tell me what the sequence of mouse/key clicks from the start menu?
> Thanks,
> Siegfried
P
PaulB
Control Panel/Administrative tools/
Paul
> Thanks,
> Siegfried
V
I get there the same way I do in XP. Right click (My)Computer, select
Manage, expand Services and Applications in the left pane to get access to
Services.
You can also simply type "services" in the Start Search entry of the start
menu.
(Dominic's advice on Ctrl-Shft-Esc gets you to Task Manager, as it does in
XP. There you can start and stop services.)
Val
Thanks,
Siegfried
B
Bruce Chambers
> Thanks,
> Siegfried
It's very much the same as it was for Win2K and WinXP: Right-click
Computer (formerly "My Computer") > Manage > Services/Services and
Applications.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety. -Benjamin Franklin
Many people would rather die than think; in fact, most do. -Bertrand Russell
