How to uninstall sp2 vista 32bit x86
3
SP2 will not remove from my PC, it says not all of the SP2 update is gone, I have to get it done because my Windows Vista Ultimate, will not upgrade from a new CD player I've been told that all programs be deactivated. I hope I hope someone can help me please.
richc46
Staff member
20,105
Location
Fairfield County, CT
3
Have not sp1 but sp2 and it will still not remove it, have seen this page before, must have sp2 completely uninstalled if you have a way how to disable applications on is important because it locks things like the need to uninstall, sry for a long explanation
Lyt
Læs fonetisk
Ordbog - Vis detaljeret ordbog
richc46
Staff member
20,105
Location
Your post was in English, before please translate.
3,375
SP2 will ikke fjerne fra min pc, det siger ikke alle de SP2-opdateringen er væk , jeg er nødt til at få det gjort , fordi min Windows Vista Ultimate , vil ikke opgradere fra en ny cd anlæg , jeg har fået at vide , at alle progrrams skal være deaktivated . Jeg håber, jeg håber nogen kan hjælpe mig venligst .
Copy of translated first post (Credit: Google Translate)
Windows Vista Ultimate should upgrade fine from SP2. The only thing I see is this: Is your copy of Windows Vista Ultimate DVD not SP2, but SP1, or no Service Pack at all?
Thanks!
Windows Vista Ultimate bør opgradere bøde fra SP2. Det eneste jeg ser, er dette: Er din kopi af Windows Vista Ultimate DVD ikke SP2, men SP1, eller slet ingen Service Pack på alle?
Tak!
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
3
:sarc: SP1 are not on the computer, so that can not be delete, sp2 has deleted some files of the sp2 update but not all ... has talked with microsoft as says, all of the sp2 files must be delete, due the job as you vil use the cd windows vista ultimate, the "UPGRADE" so you can keep "FILES, PROGRAMS, SETTINGS, please help if you understand what im wirtting. :)
