How to uninstall stubborn (or corrupt) application?
O
occam
My portable came with something called 'NTI CD & DVD -Maker 7'
pre-installed (as was Vista Business). I have no re-installation disk
for it -nor for Vista Business :(
When I tried to run the NTI software, it said it was corrupted -- please
to re-install. As I could not re-install, I decided to uninstall it.
Alas, same problem - cannot uninstall (somenthing is corrupted).
Question - Is there some way I can force the uninstallation of this
program ?
(I do not want to re-install the 'factory image' which came with the
Acer machine just to be able to rescue or uninstall this one application.)
Thanks for any pointers.
M
Mick Murphy
Acer have used NTI CD-burner software for years, instead of Nero, etc.
Acer's respone has always been full reinstall!
As you don't have a disk(Acer again!), forget about that burning program,
and install Nero, or whatever CD-Burning Program that you wish to.
You DON'T have to uninstall NTI, to install a new program to do the job
Just forget about it; and don't try to open it!
Cheers!
Mick Murphy - Qld - Australia
> program ?
C
"occam" <occam@xxxxxx> wrote in message
news:ub3BS7HfIHA.3940@xxxxxx
> pre-installed (as was Vista Business). I have no re-installation disk for
> to re-install. As I could not re-install, I decided to uninstall it. Alas,
> program ?
> (I do not want to re-install the 'factory image' which came with the Acer
occam,
See the link below.
http://www.ntius.com/support.asp
C.B.
It is the responsibility and duty of everyone to help the underprivileged
and unfortunate among us.
J
Look for a program called Installer Cleanup... msicuu2.exe
> program ?
