How to view remote certificates installed on remote machine?
On local machine, in powershell I could type in : cd cert:
Then I can navigate the certificates installed on local machine.
My questions is how could I use powershell running on local machine to
view remote machine's certficate?
Thanks a lot.
B
Bob Landau
I suspect you are talking about viewing this in v1; alas I don't believe
Powershell or WMI provide any method of doing this. You can use the
Cerfticate snapin to view these though
http://msdn.microsoft.com/en-us/library/ms788967.aspx
If you can use v2 check out the help for invoke-command. This can now be
done easily.
bob
> Thanks a lot.
Thanks a lot.
I will try it.
On Feb 20, 1:48 am, Bob Landau <BobLan...@xxxxxx>
> done easily.
> bob
> > Thanks a lot.
