HP 1320 (XP) driver problem in Vista 64
GaryR
Posts
4
I have a 1320 connected via USB to a Vista 64 box on a LAN. The LAN contains several XP Pro boxes and though the printer is shared I can't find a proper driver when I try to connect to it. Just keeps telling me no suitable driver found. I've tried adding an x86 driver on the Vista machine but it can't find the correct driver (I have tried pointing it directly to the HP Vista64 and a XP folder I unzipped XP drivers into). I'll connect it to an XP machine if I need to, but this shouldn't be such a PITA...
Chappy
Tech Help since 1993
Canada
Posts
357
XP drivers won't work on a Vista 64bit machine, and expecially since you're trying x86 (32bit) drivers....
HP has Vista 64bit drivers for this printer HERE.
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
GaryR
Posts
4
Dave -
Thank you for the reply. The Vista64 box the printer is hooked to (via USB) has no issues printing and the drivers installed just fine. It's the XP boxes on the LAN that can see the shared printer but can't install drivers for it from the Vista64 box or locally. All attempts to load drivers for the XP boxes fails saying it can't find suitable drivers... as does the "add drivers" routine in the printer properties when I try to add x86 drivers in Vista.
Chappy
Canada
Posts
357
Oh...your 1st post sounded like you were trying to load the x86 XP drivers on the Vista 64 machine...heheh. Now I see you're trying to point the XP machine to the folder in Vista where it can find the proper XP x86 drivers but it can't seem to find them properly. That's more like it
Now that is odd, it "should" have no problems loading those drivers...even the generic printer drivers in XP should work here or at least XP should be able to check WinUpdate for proper drivers for that model. Can't even load them locally? Have you tried allowing XP's Add New Hardware wizard to detect the printer and install drivers, or are you cancelling that and trying to go manually here?
    Personal Build
