Hyper-V Missing VMs
J
Hello everyone,
I had 20 VMs in a clustered Hyper-V, by mistake I deleted the Virtual
machine resource, now the machines are not in the Hyper-V configuration
anymore.
The files are intact and are in the LUN, but the problem is when I try to
import them a get the error:
Import failed. Unable to find virtual machine import files under location
'H:\pathtovm'. You can import a virtual machine only if you used Hyper-V to
create and export it.
Well, I know that the best way is to use the import/export procedure, but in
this scenario it was cause by a mistake...
Does anyone knows how to get these machines back to Hyper-V console?
Thank you
C
Charlie Russel - MVP
You can only import a machine that was exported. Rather than import, your
best solution is to create a new machine (name can be the same) and point to
the existing VHD(s). You'll need to recreate your settings for networking,
processors, RAM, etc.
Charlie.
http://msmvps.com/blogs/xperts64
http://mvp.support.microsoft.com/profile/charlie.russel
"John" <John@newsgroup> wrote in message
news:577D0150-6033-4D7F-9492-0D5F87FA5096@newsgroup
> Hello everyone,
> anymore.
> to
> in
> Thank you
